PIC to pic coomunicatio using I2C???
Postby nilesh15 » Fri Feb 19, 2016 10:00 am
Hi
I am communicating two pic micro controller through I2C. My Pic32 Btsk is Master and Pic24f16km202 is slave.
i want the data of ADC from Pic24f on Pic32 but initially what i am doing is , i am trying to get any constant data from pic24f micro controller.but i dont get any data.
i got acknowledged when i send address 0x00 but when i send 0x01 from master i don get any acknowledgement
 : 1 for Master configuration of PIC32 BTSK
[/// Section: Included Files
#include <machine/types.h>
#include "app.h"
// Section: Global Data Definitions
u_int8_t address;                       /* <machine/types.h> */
bool e1,e2,e3,e4,e5,e6,e7,e8,e9,e10;    /* <stdbool.h> */
// u_int32_t   timervalue,i2cvalue,i,j; /* Seem to be obsolete compatibility type definitions. */
unsigned long int   timervalue;         /* C language standard type */
__uint32_t  i2cvalue1, i2cvalue2;       /* C compiler type specified length type ? */
uint32_t    i,j;
u_int32_t COUNT=0;                        /* C library type  ? <stdint.h> */
/* Application Data
  Summary:
    Holds application data
  Description:
    This structure holds the application's data.
  Remarks:
    This structure should be initialized by the APP_Initialize function.
    Application strings and buffers are be defined outside this structure.
APP_DATA appData;
// Section: Application Callback Functions
/* TODO:  Add any necessary callback funtions.
// Section: Application Local Functions
/* TODO:  Add any necessary local functions.
void App_LED (bool e)
{            if (e)
#if  defined (Comm_Demo_Board) || defined(__32MX270F256D)
                BSP_LEDToggle(9);
                BSP_LEDToggle(0);// to check the write returns true or false value. i toogled the LED
#else
                BSP_LEDToggle(9);
                BSP_LEDToggle (0);
#endif
// Section: Application Initialization and State Machine Functions
  Function:
    void APP_Initialize ( void )
  Remarks:
    See prototype in app.h.
    /* Place the App state machine in its initial state. */
    appData.state = APP_STATE_INIT;
    /* TODO: Initialize your application's state machine and other
     * parameters.
  Function:
    void APP_Tasks ( void )
  Remarks:
    /* Check the application's current state. */
     /* Application's initial state. */
     switch ( appData.state )
        case APP_STATE_INIT:
            e1=0;e2=0;e3=0;e4=0;e5=0;e6=0;e7=0;e8=0;e9=0;e10=0;
            appData.state = APP_STATE_I2C_START;
            break;
        case APP_STATE_I2C_START :
             while(!e1)
            e1 = DRV_I2C0_MasterBusIdle();//check that the bus is free
               while(!e2)
             e2= DRV_I2C0_MasterStart();
             e1=0;
            do  {e1 = DRV_I2C0_MasterBusIdle();
            COUNT=COUNT+1;
            }while(!e1);
                    COUNT=COUNT+1;
                e4 = DRV_I2C0_ByteWrite(0x00); /* General call address */
             while(!DRV_I2C0_WaitForByteWriteToComplete());
            e5 = DRV_I2C0_WriteByteAcknowledged(); /* Now get the ACK status, inserted by Mysil. */
         //  i2cvalue1 = DRV_I2C0_ByteRead();//newn
            while(!DRV_I2C0_MasterStop());
            while(!DRV_I2C0_MasterBusIdle());           /* Wait for operation to complete. */
            e9=DRV_I2C0_MasterStart();
            while(!DRV_I2C0_WaitForStartComplete());    /* This function do not really work as expected. */
            while(!DRV_I2C0_MasterBusIdle());           /* Wait until Start is really completed. */
            while(!DRV_I2C0_MasterRestart());
            while(!DRV_I2C0_MasterBusIdle());               /* Wait until RepeatStart is really completed. */
            while(!DRV_I2C0_ByteWrite(0x01);   // I2C address with Read bit set
           e8 = DRV_I2C0_WriteByteAcknowledged();
            App_LED (e8);*/
                    e8 = DRV_I2C0_SetUpByteRead();// master receive clock byte
            App_LED (e8);
            do{
            e10 = DRV_I2C0_WaitForReadByteAvailable();  // receive byte available
            }while(!e10);// this function gives false value
            App_LED (e10);
             i2cvalue1 = DRV_I2C0_ByteRead();// if receive available then read
            DRV_I2C0_MasterNACKSend();      /* Send NACK, so Slave do not hang the bus. */
            while(!DRV_I2C0_MasterBusIdle());               /* Wait until NACK signal completed, inserted. */
            DRV_I2C0_MasterStop();
////            while(!DRV_I2C0_MasterBusIdle());               /* Wait until Stop signal is completed, inserted. */
        /* TODO: implement your application state machine.*/
            break;
        /* The default state should never be executed. */
        default:
            /* TODO: Handle error in application's state machine. */
            break;
code :2 for Slave PIC24F16KM202 microcontroller
#include "main.h"
//#include "I2C.h"
#define FCY 8000000UL
#include<libpic30.h>
unsigned short tx_data=0x99;
unsigned short j;
unsigned short rxbuffer;
//void interrupt ISR(void);
/********************** MyCode**************************
int main(void)
    CLKDIV=0;
   TRISBbits.TRISB8 = 1;// make scl1 input
   TRISBbits.TRISB9 = 1; // make sda1 input
   SSP1STAT=0;
   SSP1ADD         = 0x00;      // Set I2C address
    SSP1CON1        = 0x36;//0x003E   to enable interrupt       // SSPEN: Synchronous Serial Port Enable bit - Enables the serial port and configures the SDA and SCL pins as the serial port pins
                                    // CKP: SCK Release Control bit              - Release clock
                                    // SSPM3:SSPM0: SSP Mode Select bits         - 0110 = I2C Slave mode, 7-bit address
    //SSPSTAT        = 0x00;
    SSP1CON2        = 0x0080;// set genearal address enabled
                               // ox0081 for clock stretch with general call address enabled.
    SSP1CON3        = 0x0010;//0b 0000 0000 0001 1000
    return 0;
/*..................edited code
//*****************************************************************8
void Init()
  CLKDIV        = 0x0000;
  SSP1ADD         =  0x0000;                      // Get address (7bit). Lsb is read/write flag
  SSP1CON1        = 0x36;
  SSP1CON3        = 0x0010;//0b 0000 0000 0001 1000// Set to I2C slave with 7-bit address
void __attribute__((__interrupt__, no_auto_psv)) _SI2C1Interrupt(void)
    LATBbits.LATB2=1;
//while(!IFS1bits.SSP1IF);
     if(IFS1bits.SSP1IF == 1)
  {                // I2C Interrupt
    IFS1bits.SSP1IF = 0;                    // reset SSP interrupt flag
    //transmit data to master
    if (SSP1STATbits.R_W == 1){             // Read request from master
      SSP1BUF = tx_data;                // Get data to send
     SSP1CON1bits.CKP = 1;                  // Release SCL line
      j = SSP1BUF;
      //return;
    if (SSP1STATbits.BF == 0){              // all done,
      j = SSP1BUF;                      // Nothing in buffer so exit
     // return;
    //recieve data from master
    if (SSP1STATbits.D_A == 1){             // Data [not address]
      rxbuffer = SSP1BUF;               // get data
      j = SSP1BUF;                      // read buffer to clear flag [address]
     // return;
  j = SSP1BUF;
LATBbits.LATB2=0;
int main()
    int i;
     ANSB=0x0000;
    TRISBbits.TRISB0 = 0;// make scl1 input
    TRISBbits.TRISB1 = 0;
     TRISBbits.TRISB2 = 0;
 Init();
  while(1){
      LATBbits.LATB0=1;
      LATBbits.LATB1=0;
      for(i=0;i<10;i++)
      __delay_ms(50);
      LATBbits.LATB0=0;
      LATBbits.LATB1=1;
    //PORTB   = rxbuffer;
    tx_data = tx_data +1;
    for(i=0;i<10;i++)
    __delay_ms(50);//__Delay_ms(Delay_Time);
return 0;
i have attached the code for Slave(pic24f16km202) microcontroller and app.c file of PIC32 BTSK in which i have written the code for master configuration.
slave1.c
(3.17 KiB) Downloaded 1527 times
master_app.c
(9.5 KiB) Downloaded 1434 times
Reason: Fixed "code" tags.
nilesh15
Return to SSP (IIC, SPI)
