[ PIC16F690 ] SPI with [ ISD1760 ] voice coder chip - MPLAB.
I have been working to design an SPI interface between the pic16f690 and isd1760 voice chip using MPLAB XC8
the purpose is to be able to play four 5second sounds depending on which switch is selected (4 switches, each plays a different sound).
I am able to get the ISD chip to play on standalone mode, but that doesn't allow random address access.
I've been working on this for the past 4 weeks with no luck, i think my main issue could be the code, any help is much appreciated
below is the code i have so far - just a basic PLAY_command (it is not working)
isd1700 design guide - http://www.microtechnica.tv/support/man ... _Guide.pdf
#include <pic.h>
#define _XTAL_FREQ 8000000
// CONFIG
#pragma config FOSC = INTRCIO // Oscillator Selection bits (INTOSCIO oscillator: I/O function on RA4/OSC2/CLKOUT pin, I/O function on RA5/OSC1/CLKIN)
#pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT disabled and can be enabled by SWDTEN bit of the WDTCON register)
#pragma config MCLRE = ON // MCLR Pin Function Select bit (MCLR pin function is MCLR)
#pragma config CP = OFF // Code Protection bit (Program memory code protection is disabled)
#pragma config CPD = OFF // Data Code Protection bit (Data memory code protection is disabled)
#pragma config BOREN = OFF // Brown-out Reset Selection bits (BOR disabled)
#pragma config IESO = OFF // Internal External Switchover bit (Internal External Switchover mode is disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enabled bit (Fail-Safe Clock Monitor is disabled)
#define S0 RB5 //[record] switch
#define S1 RB7 //sound 1_ [play]switch
#define CS RC6 //chip select
#define led1 RC5 //led
//function prototypes*********************
void init(void);
void tmr_delay(unsigned short lenght);
void spi_initialize(void);
unsigned char uc_send_receive_spi(unsigned char uc_data);
//void record_M1(void);
void play_M1(void);
void main(void){
init();
while(1){
//delay(2000); //short 2secs delay
if (S1 == 0) //[play]switch 1 pressed
while(S1 == 0) continue; //wait for S1 release
play_M1();
void init(void){
//i/o config************
TRISA = 0b00000000;
TRISB = 0b10100000; //s1,s2 inputs_ reset outputs
TRISC = 0b00000000;
PORTA = 0; //CLR PORTA (0v)
//ADC OFF****************
ANSEL = 0;
ANSELH = 0;
//COMARATOR OFF**********
CM1CON0 = 0;
CM2CON0 = 0;
//TM0 CONFIG*************
T0CS = 0; //set timer 0 clock source to internal instruction clock cycle
PSA = 0; //assign prescaler to timer 0 module
PS2 = 1; //set timer 0 prescaler (bit 2)
PS1 = 1; //set timer 0 prescaler (bit 1)
PS0 = 1; //set timer 0 prescaler (bit 0)
spi_initialize();// initialize SPI mode
//reset ISD1790**********
CS = 0;
led1 = 0;
//start receiving spi command
uc_send_receive_spi(0b10000000); //turn on spi
uc_send_receive_spi(0b00000000); //stop receiving spi command
CS = 1;
tmr_delay(10); //delay 100 milisecond
CS = 0;
uc_send_receive_spi(0b11000000); //reset device
CS = 1;
CS = 0;
uc_send_receive_spi(0b11100000); //turn off spi
CS = 1;
led1 = 1;
void tmr_delay(unsigned short lenght) //delay lenght = given value*10ms
{ //delay using timer 0
for( ;lenght>0;lenght-=1)
TMR0=0; //clear timer 0 value
while(TMR0<195); //wait timer 0 value to reach 195 (10ms)
void spi_initialize(void) //check 178-179
// Set the SDO,SCL as output. SDI is automatically controlled by the SPI module.
TRISC7 = 0;
TRISB6 = 0;
// Input data sampled at middle of data output time.
SMP = 0;
// Select SPI mode 1, 1.
CKE = 0; // Output data changes on transition from idle to active clock state.
CKP = 1; // Idle state for clock is a high level.
// SPI Master mode, clock = FOSC/4.
SSPM3 = 0;
SSPM2 = 0;
SSPM1 = 0;
SSPM0 = 0;
// Clear the Write Collision Detect bit.
WCOL = 0;
// Enable the MSSP module.
SSPEN = 1;
// Send the data
SSPBUF = uc_data;
// Wait for the SPI module to finish sending / receiving.
while(BF == 0);
// Return the received data.
return SSPBUF;
void play_M1(void){
//********** TURN ON SPI ***********
CS = 0;
led1 = 0;
uc_send_receive_spi(0b10000000); //PU_
//tmr_delay(5); //(100ms)delay
uc_send_receive_spi(0b00100000); //CLR_INT
uc_send_receive_spi(0b00000010); //PLAY_
//delay(6000);
uc_send_receive_spi(0b11100000); //PD_
tmr_delay(5);
CS = 1;
led1 = 1;
__delay_ms(5000);
