18F47K42 UART interrupt keep on triggering
Setup: 18F47K42 receives through RX a continuous stream of data from another microcontroller just for test
LATAbits.LA0 simulates a normal running program, to see if something is executed, not shown in the picture but it never blinks
LATAbits.LA4 triggers when any interrupt
LATAbits.LA5 triggers only when data is in RX buffer, ready to be read (this part apparently seems to work ok).
but for some reason, something else keeps on triggering the interrupt
this is the code.
I only activated General, RX and TX interrupt, yet is triggering like madness, even try to insert this to see if any difference (even if I know some PIRbits are read only)
Nope... still triggers the same. I think maybe I need to set or unset something in INCONx or maybe U1ERRIE some bit, or is not even related to UART... I don't know anymore. Anyone have any idea or see something I don't see at the moment.
https://www.tme.eu/Document/475e508ddf619bca87f4a27ea9509268/PIC18F47K42.pdf
this is the code.
#include <pic18f47k42.h>
#pragma config FEXTOSC = LP // External Oscillator Selection (LP (crystal oscillator) optimized for 32.768 kHz; PFM set to low power)
#pragma config RSTOSC = HFINTOSC_64MHZ// Reset Oscillator Selection (HFINTOSC with HFFRQ = 64 MHz and CDIV = 1:1)
#pragma config CLKOUTEN = OFF // Clock out Enable bit (CLKOUT function is disabled)
#pragma config PR1WAY = OFF // PRLOCKED One-Way Set Enable bit (PRLOCK bit can be set and cleared repeatedly)
#pragma config CSWEN = OFF // Clock Switch Enable bit (The NOSC and NDIV bits cannot be changed by user software)
#pragma config FCMEN = ON // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor enabled)
#pragma config MCLRE = EXTMCLR // MCLR Enable bit (If LVP = 0, MCLR pin is MCLR; If LVP = 1, RE3 pin function is MCLR )
#pragma config PWRTS = PWRT_OFF // Power-up timer selection bits (PWRT is disabled)
#pragma config MVECEN = OFF // Multi-vector enable bit (Interrupt contoller does not use vector table to prioritze interrupts)
#pragma config IVT1WAY = OFF // IVTLOCK bit One-way set enable bit (IVTLOCK bit can be cleared and set repeatedly)
#pragma config LPBOREN = OFF // Low Power BOR Enable bit (ULPBOR disabled)
#pragma config BOREN = OFF // Brown-out Reset Enable bits (Brown-out Reset disabled)
#pragma config BORV = VBOR_2P45 // Brown-out Reset Voltage Selection bits (Brown-out Reset Voltage (VBOR) set to 2.45V)
#pragma config ZCD = OFF // ZCD Disable bit (ZCD disabled. ZCD can be enabled by setting the ZCDSEN bit of ZCDCON)
#pragma config PPS1WAY = ON // PPSLOCK bit One-Way Set Enable bit (PPSLOCK bit can be cleared and set only once; PPS registers remain locked after one clear/set cycle)
#pragma config STVREN = ON // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config DEBUG = OFF // Debugger Enable bit (Background debugger disabled)
#pragma config XINST = OFF // Extended Instruction Set Enable bit (Extended Instruction Set and Indexed Addressing Mode disabled)
#pragma config WDTCPS = WDTCPS_31// WDT Period selection bits (Divider ratio 1:65536; software control of WDTPS)
#pragma config WDTE = OFF // WDT operating mode (WDT Disabled; SWDTEN is ignored)
#pragma config WDTCWS = WDTCWS_7// WDT Window Select bits (window always open (100%); software control; keyed access not required)
#pragma config WDTCCS = SC // WDT input clock selector (Software Control)
#pragma config BBSIZE = BBSIZE_512// Boot Block Size selection bits (Boot Block size is 512 words)
#pragma config BBEN = OFF // Boot Block enable bit (Boot block disabled)
#pragma config SAFEN = OFF // Storage Area Flash enable bit (SAF disabled)
#pragma config WRTAPP = OFF // Application Block write protection bit (Application Block not write protected)
#pragma config WRTB = OFF // Configuration Register Write Protection bit (Configuration registers (300000-30000Bh) not write-protected)
#pragma config WRTC = OFF // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
#pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
#pragma config WRTSAF = OFF // SAF Write protection bit (SAF not Write Protected)
#pragma config LVP = OFF // Low Voltage Programming Enable bit (HV on MCLR/VPP must be used for programming)
#pragma config CP = OFF // PFM and Data EEPROM Code Protection bit (PFM and Data EEPROM code protection disabled)
#define _XTAL_FREQ 64000000
void __interrupt() RX (void);
unsigned char data=0;
void main(void) {
ANSELA=0;
ANSELC=0;
TRISA=0;
LATA=0;
LATAbits.LA0=0; //hook
LATAbits.LA4=0; //hook
LATAbits.LA5=0; //hook
//UART init
U1ERRIE=0;
U1RXPPS=0b00010111; // PPS
RC6PPS=0b00010011; // PPS
U1CON0=0b00110000;
U1BRGH=1; // BAUD 9600
U1BRGL=159; // BAUD 9600
U1CON1bits.ON=1;
INTCON0bits.GIE=1;
INTCON0bits.IPEN=0; // NO priorities
PIE3bits.U1TXIE=1; // enable TX interrupt
PIE3bits.U1RXIE=1; // enable RX interrupt
//UART init
__delay_ms(100);
while(1){
LATAbits.LA0=0;
__delay_ms(100);
LATAbits.LA0=1;
__delay_ms(100);
} //while
void __interrupt() RX (void){
if(PIR3bits.U1RXIF) {
data=U1RXB;
LATAbits.LA5=LATAbits.LA5^1;
LATAbits.LA4=LATAbits.LA4^1;
PIE0=0; // desperation
PIE1=0; // desperation
PIE2=0; // desperation
PIE3=0; // desperation
PIE4=0; // desperation
PIE5=0; // desperation
PIE6=0; // desperation
PIE7=0; // desperation
PIE8=0; // desperation
PIE9=0; // desperation
PIE10=0; // desperation
PIR0=0; // desperation
PIR1=0; // desperation
PIR2=0; // desperation
PIR3=0; // desperation
PIR4=0; // desperation
PIR5=0; // desperation
PIR6=0; // desperation
PIR7=0; // desperation
PIR8=0; // desperation
PIR9=0; // desperation
PIR10=0; // desperation
