Problems with compiling interrupt routine with XC8
Postby Andrea9765 » Sat Jan 05, 2019 6:27 pm
Hello, I'm trying to compile a project for PIC16F887 with XC8, this routine gives me some problems:
void interrupt isr(void)
if (SSPIF)
SSPIF = 0;
isrEnd = 1;
This is the error that the compiler gives me:
make[2]: *** [build/default/production/main.p1] Error 1
main.c:36:6: error: variable has incomplete type 'void'
main.c:36:15: error: expected ';' after top level declarator
2 errors generated.
(908) exit status = 1
Anybody can help me ? Thanks very much
Andrea9765
Re: Problems with compiling interrupt routine with XC8
Postby ric » Mon Jan 07, 2019 12:32 am
Which version XC8 are you using?
If it is XC8 v2.0, which mode? (C90 or C99?)
Postby Rusettsten » Sat Jan 19, 2019 9:19 am
You need to make the interrupt to be "void __interrupt() ISR (void)"
Rusettsten
Postby ric » Sat Jan 19, 2019 9:24 am
Rusettsten wrote:You need to make the interrupt to be "void __interrupt() ISR (void)"
That's true if they are using C99 mode, hence my questions in the previous post, which are still unanswered.
Return to SCI/USART/EUSART
