uart communication with pic16f886
I am using PIC16F886 with 11.059Mhz crystal. I have tested below code with PIC18F24K40 its working fine with 8Mhz internal oscillator.
When i test below code with 11.059 crystal oscilator i am getting garbage value.
Since both pin configration are equal i dont know why it give garbage value
#include <htc.h>
#include <stdio.h>
#include<pic.h>
#include<stdint.h>
#include "delay.h"
//#define _XTAL_FREQ 11.059e6
unsigned int i=0;
#define LED_RX RC7 // Pin assigned RX LED
#define LED_TX RC6 // Pin assigned TX LED
#define LED RC2 // Pin assigned for LED
#define DE RC5
#define RECEIVE 0
#define TRANSMIT 1
#define READ_REG 3
#define WRITE_REG 6
#define ILLEGAL_DATAVALUE 0x03
#define FALSE 0
#define TRUE 1
#define METER_ID 1
unsigned int j=0;
unsigned char* str;
unsigned int count = 0;
char data = 0;
unsigned char rxbuf[50];
unsigned char ser_data[95];
unsigned char crc_data[95];
unsigned char Max_scroll = 0;
unsigned char buff[10];
volatile uint8_t index = 0, rec_flag = 0, Delay_count = 0, Id[10], Buffer_count = 0, Cal_count = 0, Disp_count = 0, inc = 0, One_sec_update = 0, Auto_scroll_count = 0;
char data1[10];
unsigned char buf[20];
unsigned short int cnt, num,Dgt=0;
unsigned int j;
#define Notes_Index 25
unsigned int Toff_counter=0;
unsigned int POn_Flag=1;
unsigned int Poff_Flag=0;
void Serial_1_Send_byte(uint8_t trbuf1)
TXREG = trbuf1;
while(TRMT==0);
void Send_string_uart1(const unsigned char *string)
unsigned char i = 0;
do {
TXREG = string[i++];
while(TRMT==0);
} while (string[i] != '\0');
char Serial_Receive_byte()
while(0==PIR1bits.RCIF);
return RCREG;
char usart_RxString()
while(*str !='\0')
{ // while not end of string
RCREG = *str; // read next character
str++; // increment pointer to next character
return RCREG; // return the contents of uart
void Timer1_Interrupt()
INTCON = 0b00000000;
PIE1=0b00000001;
PIR1=0x01;
TMR1H=0x0B;
TMR1L=0xDC;
T1CON=0x31;
// T1CON=0x01;
void Init_Controller()
cnt=100;
TRISC = 0x80; //RX port configured as input
PORTC = 0x80;
TRISB=0X00;
PORTB = 0X00;
TRISA=0X00;
PORTA=0X00;
ADCON0 = 0b00000000;
ANSEL = 0b00000000;
Timer1_Interrupt();
LED=0;
//Below code make Ton and Toff time in equal Interval
void interrupt isr(void)
if(TMR1IF==1)
TMR1H=0xF8;
TMR1L=0xE8;
TMR1IF=0;
Dgt++;
LED =! LED;
void Serial_1_Init()
//SPBRG1=103; // Baud Rate 9600
//SPBRG1=51; // Baud Rate 19200
SPBRGH= 0x00; // 9600 Baud Rate for 64Mhz
SPBRG = 0x17;
TXSTA=0b00100010; // Low Speed mode
RCSTA=0b10010000;
BAUDCTL=0b01001000; //16bit baudrate has used
// RCIE=1;
// RCIF=0;
//CCP1IE=1;
void UART_Init(int baudRate)
TRISC=0x80; // Configure Rx pin as input and Tx as output
RCSTA=0b10010000;
SPBRG = (11059200UL/(long)(64UL*baudRate))-1;
RCIE=1;
// RCIF=0;
//CCP1IE=1;
void UART_TxChar(char ch)
while(TXIF==0); // Wait till the transmitter register becomes empty
TXIF=0; // Clear transmitter flag
TXREG=ch; // load the char to be transmitted into transmit reg
char UART_RxChar()
while(RCIF==0); // Wait till the data is received
RCIF=0; // Clear receiver flag
return(RCREG); // Return the received data to calling function
void main(void)
Init_Controller();
Timer1_Interrupt();
Serial_1_Init();
// UART_Init(9600);
GIE=1;
PEIE=1;
TMR1IE=1;
unsigned char c=0;
Send_string_uart1("Welcome back");
// Serial_1_Send_byte(1);
//UART_TxChar(1);
DelayMs(1000);
