REFOCON not outputting max system clock
I am using PIC18F42K80. I am trying to output same clock frequency that is being produced for CPU, with REFOCON register ( RC3/REFO pin as output). I was successful until I tried outputting maximum clock frequency, at which this PIC can operate.
Internal oscillator (INTIO1 mode):
If I set internal oscillator to 16MHz and then multiply that by 4 with PLL, I should be getting 64MHz clock frequency at REFO pin, but I get no signal (checked with oscilloscope). I get signal at REFO pin only for frequencies as high as 32MHz.
External oscillator (EC3IO mode):
With external oscillator driving PIC at 64 MHz frequency (obviously, no PLL multiplication is used), I also get nothing at REFO pin (no division used within REFOCON), but get signal, if I set division of frequency at REFOCON register by 2 (or lower) - that is (again) maximum of 32 MHz clock frequency signal.
According to my speculations, I would guess there is some unknown limitation within PIC itself, rather than software based error, since clock signal is reproduced for all clock frequencies below (including) 32 MHz clock signal. Here's code for INTIO1 mode (header file included):
// OSCILLATOR CONFIGURATION
OSCCONbits.IRCF = 0b111 ; // internal oscillator set to 16 MHz
OSCCONbits.SCS = 0b00; // primary oscillator clock is selected
OSCTUNEbits.PLLEN = 1; // PLL enabled
while(OSCCONbits.HFIOFS != 1); // wait until oscillator frequency is stable
// REFERENCE OSCILLATOR AT RC3
REFOCONbits.ROSEL = 0; // system clock used as base clock of reference oscillator at RC3
REFOCONbits.RODIV = 0b0000; // base clock value (not divided)
REFOCONbits.ROON = 1; // reference oscillator enabled
