4/8bit LCD library for HD44780, HD47780, ST7036 TestProject
Postby vloki » Wed Apr 29, 2015 10:49 am
MPLAB-X project with differnt configurations for testing LCD lib
on different boards and with different PICs and compilers.
- PICDEM 2+, PIC18F4520, XC8
- PICDEM USB, PIC18F4550, C18
- custom board, PIC18F25K22, C18 + XC8
(? http://www.microchip.com/forums/FindPost/860680 )
<edit> added 8bit data support ...
LCD_LIB_TEST_20150608.zip
(16.14 KiB) Downloaded 860 times
Re: 4/8bit LCD library for HD44780, HD47780, ST7036 TestPro
Postby ric » Tue Jul 31, 2018 4:33 am
In LCD_LIB_BUSY.H
// Cursor / Display shift       0   0   |   0   0   0   1   S/C R/L -   -
    #define DISPLAY_SHIFT_R     0x1C
    #define DISPLAY_SHIFT_L     0x18
    #define CURSOR_MOVE_R       0x14
    #define CURSOR_MOVE_L       0x14
The last line should be 0x10, not 0x14
Postby vloki » Wed Aug 01, 2018 7:28 am
Oh, yes.
My git repository tells me that I corrected that in November 2015.
Guess it was never used until now ;-)
There is at least one more thing that should be corrected.
In the same header a delay after the Clear display macro was added;
void LCD_Init(void);
#define LCD_Clear() LCD_Command(CLEAR_DISPLAY); LCD_DELAY_5MS()
#define LCD_Home()  LCD_Command(RETURN_HOME); LCD_DELAY_5MS()
I should rebuild the test project with actual sources and post it here...
Postby ric » Mon Feb 04, 2019 9:44 am
I've removed posts by "RodneyBoris" and "RobertAlvarado", and banned both users, after they edited their posts to include hidden spammy links.
Return to Graphics and LCD
