an Audio Amplifier with PIC
Postby DarioG » Tue Nov 14, 2017 1:11 pm
(going on with some funny applications...)
Using a PIC24 or a dsPIC, grab analog input from a Microphone, convert it (22/44 Ksamples/sec) into numbers, scale for PWM and send them to a speaker!
Several types of PICs can be used: a 70MIPS device with remappable pins is best, but not needed.
Using a 140MHz device we set PWM at 35KHz and drive the 2 PWM outputs in order to achieve the "power": keeping in mind the average limit of 20mA per pin/200mA maximum total, in theory up to 10+10 pins could be used - and deliver 3W over a 8ohm speaker.
4+4 output would also be good. At a very basic level, 1+1 pins are a starting point for this demo.
Of course the signal coming from Microphone (or other source) can easily be scaled or filtered in code.
Have (more) fun! :)
PICAmplif.pdf
(11.82 KiB) Downloaded 958 times
picfruit24_amplif.zip
(13.18 KiB) Downloaded 951 times
All we are praying / is an earthquake in Chandler
DarioG
Re: an Audio Amplifier with PIC
Postby DarioG » Tue Nov 14, 2017 6:02 pm
Some notes:
of course you can use external buffers (darlington, 7404 or 4049) in order to increase the power.
I noticed I made a mistake: 200mA over 8ohm make only 0.32W :)
Another mistake: *all* of the current is coming from the PIC, so only 10 pins can be used (not 20)
DarioG
Return to CCP, ECCP and PWM
