I have a problem with the RTCC clock setting
Processor: P18F87K22 with RTCC
The processor is operated with internal clock source (32MHz).
The setting is done according to the datasheet and is OK.
In parallel I want to use the RTCC module with external clock source
(crystal = 32.768 KHz).
I can't find suitable parameters for this mode.
Connection: Pin 50 = OSC2/CLKO/RA6 = In/Out Pin
Pin 49 = OSC1/CLKI/RA7 = In/Out Pin
Pin 36 = SOSCO/RC0 = Crystal Pin1 (32.768 KHz)
Pin 35 = SOSC/RC1 = Crystal Pin2
My question: Can both frequencies run at the same time ?
What settings do I have to make ?
Thanks in advance for all hints!
