*(SOLVED)* - Can't make some inputs work? PIC18F45K50
Hi Guys,
I have tried everything I know with this one. I have used many PICs over the years but the PIC18F45K50-I/P (dip 40p) is new to me so that's likely most of my problem. I am writing in assembler and using MPLAB IDE v8.92 (I can't understand MPLABX, it's too complex for my small brain).
I have the chip working, driving things as well as some inputs working BUT for the life of me I just cannot get RA0 (pin 2) and RA1 (pin 3) to 'see' any change applied to the pin.
Any suggestions most welcome - a code snippet here with (hopefully) the area of interest in there somewhere:
LIST P=PIC18F45K50 ;DEFINE PROCESSOR
#INCLUDE <P18F45K50.inc> ;INCLUDE DEFAULTS
ERRORLEVEL -302
ERRORLEVEL -305 ;W OR F ERROR
CONFIG WDTEN = OFF ;disable watchdog timer
CONFIG MCLRE = OFF ;MCLEAR Pin on RE3 - OFF
CONFIG DEBUG = OFF ;DISABLE Debug Mode
CONFIG LVP = OFF ;Low-Voltage programming disabled
CONFIG FOSC = INTOSCIO ;Internal oscillator, port function on RA6
CONFIG BOREN = OFF ;BROWN OUT DETECTOR OFF
CONFIG PBADEN = OFF ;FORCE PORT B PINS TO BE DIGITAL AT BOOT
CONFIG XINST = OFF ;EXTENDED INSTRUCTION SET OFF - MIGHT NOT BE NEEDED?
ORG 0x00
GOTO INIT
ORG 0X08
GOTO INIT
ORG 0X18
GOTO INIT
INIT
CBLOCK 0x00
DELAY1
DELAY2
ENDC
MOVLW B'01010100' ;SET OSC FOR 4MHZ
MOVWF OSCCON
CLRF LATA
CLRF ANSELA ;ALL PORTS DIGITAL
MOVLW B'00000011'
MOVWF TRISA
CLRF LATB
CLRF ANSELB ;ALL PORTS DIGITAL
MOVLW B'00000000'
MOVWF TRISB
CLRF LATC
CLRF ANSELC ;ALL PORTS DIGITAL
MOVLW B'00000011'
MOVWF TRISC
CLRF LATD
CLRF ANSELD ;ALL PORTS DIGITAL
MOVLW B'00000000'
MOVWF TRISD
CLRF LATE
CLRF ANSELE ;ALL PORTS DIGITAL
MOVLW B'00001111'
MOVWF TRISE
#DEFINE GO_UP PORTE,3 ;PIN 1 MCLR, TIED HIGH WITH 47K
#DEFINE ENTER PORTA,0 ;PIN 2 INPUT TEST BUTTON ENTER TIED HIGH WITH 10K
#DEFINE TEST PORTA,1 ;PIN 3 INPUT TEST BUTTON TEST TIED HIGH WITH 10K
code continues from here - cut to the 'read the input' section using simple code to read the input pin here:
START
BTFSC TEST ;USING ENTER OR TEST HERE ISN'T RECOGNISED - GO_UP WORKS PERFECTLY AND AS EXPECTED
GOTO START
ERRORLEVEL -302
ORG 0x00
GOTO INIT
ORG 0X08
GOTO INIT
ORG 0X18
GOTO INIT
INIT
CBLOCK 0x00
DELAY1
DELAY2
ENDC
MOVWF OSCCON
CLRF LATA
MOVLW B'00000011'
MOVWF TRISA
CLRF LATB
MOVLW B'00000000'
MOVWF TRISB
CLRF LATC
MOVLW B'00000011'
MOVWF TRISC
CLRF LATD
MOVLW B'00000000'
MOVWF TRISD
CLRF LATE
MOVLW B'00001111'
MOVWF TRISE
START
GOTO START
