Connection problems to PIC18F4685
Hi this is the first time I am burning a hex file onto a pic18f4685, I have pickit 3.5 and an expansion board for the pic18f4685 i connected it to the far right of the connector at the bottom of the pickit 3.5 the expansion board has 5 pins the pickit3. 5. 6pins. There are 4 settings for the jumpers on the expansion board pic10FX, DIP8/14 DIP 18/20, 16F57, and DIO40/28 I have mine set for PIC10FX, when trying to connect to the burner with chip connected in the expansion board I get the message
"CAUTION check that the device selected in mplab ipe(pic18f4685> is the same one that is physically attached to the debug tool.
Selecting a 5v device when a 3.3 v device is connected can result in damage to the device when the debugger checks the device id
Do you wish to continue.? "
I select yes
Then click connect.
In red I get writing" Target device was not found (could not detect target voltage vdd). You must connect a target device to use PICkit 3.“
In mplab ipe i have family set to Advanced 8-bit MCUs (PIC18), device set to PIC 18F4685 and tool sets automatically to pickit3 s. No: BUR195068601
Please can someone direct me as how to establish a connetion to the pic18f4685 via the pickit 3.5.
Many thanks
I select yes
Then click connect.
Many thanks
