Re: Modify Hex file to add a logo to the thermal printer rec
Posted: Sun Nov 08, 2020 10:43 am
I guess you will need to write a program to read the data and reformat it into the required format using multiple characters.
An unofficial support site for PIC users. Note: This site is not approved or endorsed by Microchip Inc.
http://picforum.ric323.com/
print(0x00);
print(0x01);
print(0x02);
print(0x03);
delay_ms(1000);
beez_time=BEEP;
print(13);//go to new line
print(0x04);
print(0x05);
print(0x06);
print(0x07);
delay_ms(1000);
beez_time=BEEP;
print(13);
print(0x08);
print(0x09);
print(0x0A);
print(0x0B);
delay_ms(1000);
beez_time=BEEP;
print(0x0C);
print(0x0D);
print(0x0E);
print(0x0F);
delay_ms(1000);
beez_time=BEEP;
print(0x10);
print(0x11);
print(0x12);
print(0x13);
delay_ms(1000);
beez_time=BEEP;
print(0x14);
print(0x15);
print(0x16);
print(0x17);
delay_ms(1000);
beez_time=BEEP;
/*0x01*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x8f, 0xbf, 0xff, 0xff, 0xff, 0xff, 0x83, 0xbf}},
/*0x02*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0xff, 0xff, 0xff, 0xff, 0x81, 0xbf, 0xff, 0xff, 0xff, 0xff, 0x80, 0xbf, 0xff, 0xff, 0xff, 0xff }},
/*0x03*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0xc0, 0xbf, 0xff, 0xff, 0xff, 0xff, 0xc0, 0xbf, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x3f, 0xff, 0xff}},
/*0x04*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0xff, 0xff, 0xf0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xdf, 0xbf}},
/*0x05*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0xff, 0xff, 0xff, 0xff, 0xdf, 0x83, 0xff, 0xff, 0xff, 0xfe, 0xff, 0xfc, 0x7f, 0xff, 0xff, 0xef }},
/*0x06*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0xff, 0xff, 0x1f, 0xff, 0xff, 0xfe, 0xff, 0xff, 0xcf, 0xff, 0xff, 0xef, 0xff, 0xff, 0xf3, 0xff }},
/*0x07*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0xff, 0xff, 0xbf, 0xfe, 0xf9, 0xff, 0xff, 0xcf, 0x8f, 0xf0, 0xfc, 0xff, 0xfe, 0x7f, 0x01, 0xc2}},
/*0x08/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0x7e, 0x7f, 0xff, 0x7f, 0x70, 0x87, 0x7f, 0x7f, 0xfc, 0xff, 0x7e, 0x9f, 0x3f, 0xbf, 0xff, 0xfe}},
/*0x09*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0x7e, 0x3f, 0x3f, 0xdf, 0xfb, 0xfe, 0x7e, 0x3f, 0x9f, 0xdf, 0xff, 0xfe, 0xfc, 0x9f, 0x9f, 0xef}},
/*0x0A*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0xfb, 0xfe, 0xf8, 0xcf, 0x9f, 0xef, 0xff, 0xf0, 0x09, 0xe0, 0x07, 0xf7, 0xf7, 0xe0, 0x03, 0xe0}},
/*0x0b*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0x00, 0xf7, 0xff, 0x0c, 0xfb, 0xf7, 0x98, 0x37, 0xfc, 0x3e, 0xff, 0xff, 0xbf, 0x3b, 0xfe, 0x7e }},
/*0x0c*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0xff, 0x7f, 0xbf, 0x3b, 0xfe, 0x7e, 0xff, 0xff, 0x9f, 0x3b, 0xff, 0x7e, 0xfd, 0xff, 0x9f, 0x3b}},
/*0x0d*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0xff, 0x3e, 0x7f, 0xfd, 0x9e, 0x7d, 0xdf, 0xbc, 0xfd, 0xf1, 0x8f, 0x7d, 0xdf, 0xb9, 0xff, 0xff }},
/*0x0e*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0xe6, 0x7d, 0xff, 0x83, 0xe3, 0x77, 0xf0, 0xfd, 0xff, 0xc7, 0xff, 0xe7, 0xf9, 0xfd, 0xff, 0xc3 }},
/*0x0f*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0xff, 0x5f, 0xf0, 0xfd, 0xff, 0xc1, 0xff, 0xbf, 0xe6, 0xfd, 0xcf, 0x98, 0xed, 0x6f, 0xce, 0x7d }},
/*0x10*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0xef, 0x9e, 0x7f, 0xf7, 0x1e, 0x7b, 0xef, 0x9f, 0x7f, 0xc7, 0xbf, 0x3b, 0xff, 0x3f, 0x7d, 0xff }},
/*0x11*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
{0x9f, 0x3b, 0xef, 0x3f, 0x77, 0xff, 0x9f, 0xbb, 0xfb, 0x7f, 0x7f, 0xff, 0x9f, 0x17, 0xf6, 0x3f }},
/*0x12*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},//POINTING RIGHT(ALT+16)
{0x7b, 0xf0, 0x1c, 0x77, 0xff, 0x86, 0x01, 0xe0, 0x00, 0xf7, 0xfb, 0xf0, 0x0c, 0xef, 0x83, 0xef}},
/*0x13*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},//POINTING DOWN(ALT+31)
{0xf3, 0xf9, 0x7c, 0x4f, 0xdf, 0xef, 0xfd, 0xff, 0x7e, 0x1f, 0x9f, 0xdf, 0xfe, 0x7f, 0x7f, 0x3f }},
/*0x14*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},//>
{0x9f, 0xdf, 0xfc, 0xff, 0x3f, 0x1f, 0xbf, 0xbf, 0xfe, 0xff, 0xbf, 0x07, 0x3f, 0x7f, 0xff, 0xff }},
/*0x15*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},//<
{0x98, 0x43, 0x3e, 0x7f, 0xff, 0xcf, 0x90, 0xf8, 0x7c, 0xff, 0xff, 0xff, 0xc3, 0xfe, 0x79, 0xff }},
/*0x16*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},//=
{0xff, 0xdf, 0xdf, 0xff, 0x73, 0xff, 0xff, 0xf0, 0xff, 0xff, 0xcf, 0xff, 0xff, 0xff, 0xff, 0xff }},
/*0x17*/{{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},//)
{0x9f, 0xff, 0xff, 0xfe, 0x7f, 0xfc, 0x7f, 0xff, 0xff, 0xff, 0x5f, 0x83, 0xff, 0xff, 0xff, 0xff }},
