MPLAB C18
MPLAB C18
Postby Dimebag » Sun Jul 06, 2014 9:13 am
Clean: Deleting intermediary and output files.
Clean: Deleted file "D:\Program Files\Microchip\MPASM Suite\LKR\Ctest.o".
Clean: Deleted file "D:\Program Files\New folder\ProjectCtest.mcs".
Clean: Done.
Executing: "C:\Program Files\Microchip\mplabc18\v3.47\bin\mcc18.exe" -p=18F452 "Ctest.c" -fo="Ctest.o" /i"C:\Program Files\Microchip\mplabc18\v3.47\inc" -w3 -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
MPLAB C18 3.47 (evaluation)
Copyright 2000-2011 Microchip Technology Inc.
Days remaining until evaluation becomes feature limited: 60
WARNING: Running the compiler in extended mode will not be supported when the evaluation becomes feature limited.
Executing: "D:\Program Files\Microchip\MPASM Suite\MPLink.exe" /l"C:\Program Files\Microchip\mplabc18\v3.47\lib" "D:\Program Files\Microchip\MPASM Suite\LKR\18f452.lkr" "D:\Program Files\Microchip\MPASM Suite\LKR\Ctest.o" "C:\Program Files\Microchip\mplabc18\v3.47\lib\p18f452.lib" /o"ProjectCtest.cof"
MPLINK 3.94, Linker
Copyright (c) 2005 Microchip Technology Inc.
Error - Coff file 'D:\Program Files\Microchip\MPASM Suite\LKR\Ctest.o' does not appear to be a valid COFF file.
Errors : 1
BUILD FAILED: Sun Jul 06 18:08:30 2014
My first time in C18. I have MPLAB 7.20 installed. Some ideas what I need to do to fix this failure please.
Dimebag
Re: MPLAB C18
Postby Dimebag » Sun Jul 06, 2014 9:45 am
Clean: Done.
Skipping link step. The project contains no linker script.
BUILD FAILED: Sun Jul 06 18:41:57 2014
hmm I don't appear to have a correct linker file. any one got a spare linker file available
Dimebag
Re: MPLAB C18
Postby vloki » Sun Jul 06, 2014 10:23 am
Dimebag wrote:My first time in C18. I have MPLAB 7.20 installed. Some ideas what I need to do to fix this failure please.
7.20 ???
Guess such old MPLAB version is not compatible with C18 3.47.
Dimebag wrote:Clean: Deleting intermediary and output files.
I have not used MPLAB for some years now because I switched to MPLAB-X
but your project organization seems to be a bit curious.
Try to use the project wizard when starting a new project and do not place projects
inside the program installation folders
Re: MPLAB C18
Postby Dimebag » Sun Jul 06, 2014 10:49 am
I downloaded MPLABX v2.15 the other day. I am not sure how to use it yet.
Dimebag
Re: MPLAB C18
Postby vloki » Sun Jul 06, 2014 10:56 am
Another thing about the 452 you seem to use:
We used this PIC years ago in our student labs on PICDEM 2+ boards.
Later we replaced them with 4520 because of internal oscillator and other improvements
In the meantime we switched again and are using 45K22 and 25K22 chips on our lab boards.
If you easily could get a more recent pic like the 45K22 I would recommend that you stop
wasting time with outdated 452
Re: MPLAB C18
Postby vloki » Sun Jul 06, 2014 10:58 am
Dimebag wrote:I downloaded MPLABX v2.15 the other day. I am not sure how to use it yet.
In my personal experience it is MUCH more easy to use for beginners than classic MPLAB
Re: MPLAB C18
Postby Dimebag » Sun Jul 06, 2014 11:08 am
PLINK 3.94, Linker
Errors : 1
I think I need the correct linker file.
Dimebag
Re: MPLAB C18
Postby Dimebag » Sun Jul 06, 2014 11:11 am
I was told that C compliers are easier to use. I am trying to be updated as much as I can.
Dimebag
Re: MPLAB C18
Postby vloki » Sun Jul 06, 2014 11:59 am
So you use MPLAB-X now ?
What hardware do you have ?
MCHP demo board ?
Debugger ?
Re: MPLAB C18
Postby vloki » Sun Jul 06, 2014 12:24 pm
Dimebag wrote:
PLINK 3.94, Linker
Errors : 1
I think you need to read the C18 compiler readme
MPLINK™ Linker and MPLAB IDE COFF File Format
Due to a change in COFF file format, MPLAB C18 v3.00 and later will not be compatible with versions of MPLINK Linker prior to v4.00 or versions of the MPLAB IDE prior to v7.21
