Serial Buffer Not Reading PIC 18F45K22
Postby SLTom992 » Wed Jul 02, 2014 5:02 pm
I have SSP1 set up for serial date input in the Master Mode.
On the scope you can see the SCK1 clocks and you can see the SDI data at the input pin. When I read SSP1BUF there is nothing in the buffer register.
    TRISC = 0b01110000;                    // SDO no output, SDI input, SCK output
    SSP1CON1 = 0b00100000;              // Enable SSP & SCK normally low
    SSP1STAT = 0b00000000;              // CKE = clock polarity 0->1
My scope doesn't have the ability to post screen dumps but the clocks are occurring during a solid high data input and the buffer reads 0x00. So this isn't a case of incorrect clock/data polarity.
Any ideas?
SLTom992
Re: Serial Buffer Not Reading PIC 18F45K22
Postby stumichaels » Wed Jul 02, 2014 6:54 pm
Can you take a picture of your scope with a digital camera or a smart phone and post it here? It would also be helpful if you showed your code.
stumichaels
Postby SLTom992 » Wed Jul 02, 2014 8:14 pm
I've taken pictures but cannot get them to download to this group.
    (cause SCK group by SSP1BUF = 0x00;)
    if (SSP1IF) {                       // Buffer full
        measure = SSP1BUF;              // Also clears BF bit
SSP1BUF = 0x00 regardless of SDI
SLTom992
Postby ric » Wed Jul 02, 2014 9:36 pm
I haven't checked your datasheet. Can the SPI pin acts as an analog input?
If yes, you MUST switch it to digital mode first.
Postby SLTom992 » Wed Jul 02, 2014 10:14 pm
That was a very good suggestion that I hadn't thought of. But I set it up properly in the first place:
// Iniialize ADC for power level monitor
    ADCON0 = 0b00000101;                // ADC 1 Enabled
    ADCON1 = 0b00000000;                // V ref = power and ground
    ADCON2 = 0b00111110;                // (setup for clocks and read time)
The SDI port is AD16.
SLTom992
Postby Tom Maier » Thu Jul 03, 2014 3:09 am
The "Configurator" plugin might also help youi with this problem. It supposedly not only has automatic setup of config bits, but can also insert driver software in to the code.
I'll be upgrading soon and will be trying this out. It also supports the newer pic24 chips.
http://www.microchip.com/pagehandler/en ... umentation
Postby ric » Thu Jul 03, 2014 3:13 am
SLTom992 wrote:That was a very good suggestion that I hadn't thought of. But I set it up properly in the first place:
You're not writing to the appropriate ANSEL register at all.
Ahhh, I thought this sounded familiar.
I didn't realise it was also you posting at http://www.microchip.com/forums/m805840.aspx#805853 where I just gave exactly the same answer.
Postby Tom Maier » Thu Jul 03, 2014 3:16 am
I bet the "Configurator" wouldn't have made that mistake. :lol:
Have you tried that, Ric? I am always reluctant to upgrade, but that plugin has sparked my interest.
