Subroutine problem with PIC18F452
Postby Dimebag » Sun Jun 29, 2014 9:24 am
The problem is that if I hit any character the program runs to the same subroutine. I started this program years ago, I never got around to finishing it up. I am not sure how to get the program to branch off on to the different subroutines I will using later on.
This part of the code is where I have narrowed it down to.
unpackdata
   TBLRD*+                       ;read table byte, advance to next
   movf      TABLAT,W            ;get the table byte
   bz        Newpointer
   movwf     TXREG               ;save it in TXREG
   call      sentdatapack        ;make sure TXIF is set
   goto      unpackdata         ;send next byte
sentdatapack
   btfss     PIR1, TXIF          ;has the byte been sent
   goto      sentdatapack        ;no, do it again
   return    ;yes, finished.
Newpointer
This section runs all the time.
Hyper_Tlink_1;Program Mode
   movlw     b'10000000';
   movwf     PORTB
   goto      Hyper_Tlink_1
The total Program as is at the moment below.
 list p=18f452
    #include p18f452.inc
    ;18F452 Configuration Registers
    config  OSC = HS  ;crystal osc pll (4x10 = 40MHz)
    config  OSCS = OFF  ;oscillator switch enable is off
    config  PWRT = ON  ;power up timer on
    config  BOR = OFF  ;brown-out reset off
    config  BORV = 45  ;brown out voltage 4.5 volts
    config  WDT = OFF  ;watchdog timer
    config  WDTPS = 1  ;watchdog timer postscaler
    config  CCP2MUX = OFF ;disable (RB3)
    config  STVR = OFF  ;stack overflow reset disabled
    config  LVP = OFF  ;low voltage programming disabled
    config  DEBUG = OFF  ;background debugger off
    config  CP0 = OFF  ;code protection block 0
    config  CP1 = OFF
    config  CP2 = OFF
    config  CP3 = OFF
    config  CPB = OFF  ;code protection boot block
    config  CPD = OFF  ;code protection data EEPROM
    config WRT0 = OFF  ;write protection block 0
    config WRT1 = OFF
    config WRT2 = OFF
    config WRT3 = OFF
    config WRTB = OFF  ;write protection boot block
    config WRTC = OFF  ;write protection configuration register
    config WRTD = OFF  ;write protection data EEPROM
    config EBTR0 = OFF  ;table read protection block 0
    config EBTR1 = OFF
    config EBTR2 = OFF
    config EBTR3 = OFF
    config EBTRB = OFF  ;table read protection boot block
   udata
string_index   res 1
string_data      res 1
string_pointer   res 1
delay         res 1
miner         res 1
offset         res 1
track_num      res 1
track_con      res 1
track_string   res 1
temp         res 1
counter         res 1
   code
   movlw     b'00010000';Used for?
   movwf     TRISA
   movlw     b'00000000'
   movwf     PORTA
   movlw     b'00000001';Used for?
   movwf     TRISB
   movlw     b'00000000';
   movwf     PORTB
   movlw     b'00000000';
   movwf     TRISC
   movlw     b'00000000';
   movwf     PORTC
   movlw     b'00000000';
   movwf     TRISD
   movlw     b'00000000';
   movwf     PORTD
   movlw     b'00000000';
   movwf     TRISE
   movlw     b'00000000';
   movwf     PORTE
   movlw     B'01000001'   ;Fosc/8, A/D enabled
   movwf     ADCON0
   movlw     B'00001110'   ;Left justify,1 analog channel
   movwf     ADCON1   ;VDD and VSS references
reciever
   ;ASYNCHRONOUS MODE (NRZ) will be stop if entering sleep mode
;BRGH = 1
;20 MHz
;SPBRG = 129 or H'81'
   bcf         TRISC,6             ;Make RC6 an output
   movlw       0x81                ;9600 baud @20MHz
   movwf       SPBRG
   bsf         TXSTA,TXEN          ;Enable transmit
   bsf         TXSTA,BRGH          ;Select high baud rate
   bsf         RCSTA,SPEN          ;Enable Serial Port
   bsf         RCSTA,CREN          ;Enable continuous reception
   bcf         PIR1,RCIF           ;Clear RCIF Interrupt Flag
   bsf         PIE1,RCIE           ;Set RCIE Interrupt Enable
   bcf         INTCON,PEIE         ;Enable peripheral interrupts
   bcf            INTCON,GIE          ;Enable global interrupts
   goto        test_receive
test_receive
   btfss   PIR1,RCIF   ;
   goto   test_receive
   movf   RCREG,w   ;
   call    request   ;
request
       ;Program Mode
   xorlw     "A"   ;
   btfsc     STATUS,Z   ;
   goto      set1
       ;Entry Mode
   xorlw     "A"
   xorlw     "B"
   btfsc     STATUS,Z
   goto      set2
       ;Program Test
   xorlw     "B"
   xorlw     "C"
   btfsc     STATUS,Z
   goto      set3
       ;Adjust Settings
   xorlw     "C"
   xorlw     "D"
   btfsc     STATUS,Z
   goto      set4
      ;Stop
   xorlw     "D"
   xorlw     "E"
   btfsc     STATUS,Z
   goto      set5
       ;Testing Program
   xorlw     "E"
   xorlw     "F"
   btfsc     STATUS,Z
   goto      set6
      ;Program 1
   xorlw     "F"
   xorlw     "G"
   btfsc     STATUS,Z
   goto      set7
       ;Program 2
   xorlw     "G"
   xorlw     "H"
   btfsc     STATUS,Z
   goto      set8
       ;Data Mode 1
   xorlw     "H"
   xorlw     "I"
   btfsc     STATUS,Z
   goto      set9
       ;Data Mode 2
   xorlw     "I"
   xorlw     "J"
   btfsc     STATUS,Z
   goto      set10
        ;Resume Running
   xorlw     "J"
   xorlw     "K"
   btfsc     STATUS,Z
   goto      set11
       ;Quit Program
   xorlw     "K"
   xorlw     "L"
   btfsc     STATUS,Z
   goto      set12
      ;Cancel
   xorlw     "L"
   xorlw     "M"
   btfsc     STATUS,Z
   goto      set13
      ;User 1 Settings
   xorlw     "M"
   xorlw     "N"
   btfsc     STATUS,Z
   goto      set14
      ;User 2 Settings
   xorlw     "N"
   xorlw     "O"
   btfsc     STATUS,Z
   goto      set15
       ;User 3 Settings
   xorlw     "O"
   xorlw     "P"
   btfsc     STATUS,Z
   goto      set16
        ;Save Project
   xorlw     "P"
   xorlw     "Q"
   btfsc     STATUS,Z
   goto      set17
       ;Debugging
   xorlw     "Q"
   xorlw     "R"
   btfsc     STATUS,Z
   goto      set18
       ;Write to EEprom
   xorlw     "R"
   xorlw     "S"
   btfsc     STATUS,Z
   goto      set19
   ;Start Up
   xorlw     "S"
   xorlw     "T"
   btfsc     STATUS,Z
   goto      set20
   ;YES or NO
   xorlw     "T"   ;
   xorlw     "U"   ;
   btfsc     STATUS,Z   ;
   goto      set21
;       ;Continue ?
   xorlw     "U"
   xorlw     "V"
   btfsc     STATUS,Z
   goto      set22
       ;Add New Field
   xorlw     "V"
   xorlw     "W"
   btfsc     STATUS,Z
   goto      set23
       ;Try it again
   xorlw   "W"
   xorlw     "X"
   btfsc     STATUS,Z
   goto      set24
       ;Change Data to
   xorlw     "X"
   xorlw     "Y"
   btfsc     STATUS,Z
   goto      set25
       ;Send
   xorlw     "Y"
   xorlw     "Z"
   btfsc     STATUS,Z
   goto      set26
       ;Recieve
   xorlw     "Z"
   xorlw     "a"
   btfsc     STATUS,Z
   goto      set27
       ;Save
   xorlw     "a"
   xorlw     "b"
   btfsc     STATUS,Z
   goto      set28
       ;Copy
   xorlw     "b"
   xorlw     "c"
   btfsc     STATUS,Z
   goto      set29
       ;EXIT
   xorlw     "c"
   xorlw     "d"
   btfsc     STATUS,Z
   goto      set30
        ;Start Running
   xorlw     "d"
   xorlw     "e"
   btfsc     STATUS,Z
   goto      set31
       ;Servo No 1
   xorlw     "e"
   xorlw     "f"
   btfsc     STATUS,Z
   goto      set32
       ;Servo No 2
   xorlw     "f"
   xorlw     "g"
   btfsc     STATUS,Z
   goto      set33
        ;Servo No 3
   xorlw     "g"
   xorlw     "h"
   btfsc     STATUS,Z
   goto      set34
       ;Servo No 4
   xorlw     "h"
   xorlw     "i"
   btfsc     STATUS,Z
   goto      set35
       ;Run All Servo's
   xorlw     "i"
   xorlw     "j"
   btfsc     STATUS,Z
   goto      set36
       ;Select a Different?
   xorlw     "j"
   xorlw     "k"
   btfsc     STATUS,Z
   goto      set37
   ;Profile
   xorlw     "k"
   xorlw     "l"
   btfsc     STATUS,Z
   goto      set38
       ;Event
   xorlw     "l"
   xorlw     "m"
   btfsc     STATUS,Z
   goto      set39
   ;To Program
   xorlw     "m"
   xorlw     "n"
   btfsc     STATUS,Z
   goto      set40
   return
PM                 data       " Program Mode  \r\0";1    $
EM                 data       "  Entry Mode   \r\0";2    $
PT                 data       " Program Test  \r\0";3    $
AS                 data       "Adjust Settings\r\0";4    $
ST                 data       "     STOP      \r\0";5    $
TP                 data       "Testing Program\r\0";6    $
P1                 data       "   Program  1  \r\0";7    $
P2                 data       "   Program  2  \r\0";8    $
DM1                data       "  Data Mode 1  \r\0";9    $
DM2                data       "  Data Mode 2  \r\0";10   $
RR                 data       " Resume Running\r\0";11   $
QP                 data       "  Quit Program \r\0";12   $
CXL                data       "    Cancel     \r\0";13   $
U1S                data       "User 1 Settings\r\0";14   $
U2S                data       "User 2 Settings\r\0";15   $
U3S                data       "User 3 Settings\r\0";16   $
SP                 data       "  Save Project?\r\0";17   $
DEBUG              data       "  Debugging    \r\0";18   $
EEP                data       "Write to EEprom\r\0";19   $
SU                 data       "   Start Up    \r\0";20   $
YS                 data       " YES or NO     \r\0";21     $
CC                 data       " Continue ?    \r\0";22     $
NF                 data       " Add New Field \r\0";23     $
TA                 data       " Try it again  \r\0";24     $
CDATA              data       " Change Data to\r\0";25     $
SED                data       " Send          \r\0";26     $
R1                 data       " Recieve       \r\0";27     $
S2                 data       " Save          \r\0";28     $
CW                 data       " Copy          \r\0";29     $
EXIT               data       " EXIT          \r\0";30     $
SRR                data       " Start Running \r\0";31     $
SV1                data       " Servo No 1    \r\0";32     $
SV2                data       " Servo No 2    \r\0";33     $
SV3                data       " Servo No 3    \r\0";34     $
SV4                data       " Servo No 4    \r\0";35     $
RASV               data       " Run All Servo's\r\0";36    $
SDD                data       " Select a Different?\r\0";37$
PPG                data       " Profile       \r\0";38     $
EEV                data       " Event         \r\0";39     $
PU                 data       " To Program    \r\0";40     $
set1
   movlw     upper     (PM)
   movwf     TBLPTRU
   movlw     high      (PM)
   movwf     TBLPTRH
   movlw     low       (PM)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_1
set2
   movlw     upper     (EM)
   movwf     TBLPTRU
   movlw     high      (EM)
   movwf     TBLPTRH
   movlw     low       (EM)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_2
set3
   movlw     upper     (PT)
   movwf     TBLPTRU
   movlw     high      (PT)
   movwf     TBLPTRH
   movlw     low       (PT)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_3
set4
   movlw     upper     (AS)
   movwf     TBLPTRU
   movlw     high      (AS)
   movwf     TBLPTRH
   movlw     low       (AS)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_4
set5
   movlw     upper     (ST) ;
   movwf     TBLPTRU
   movlw     high      (ST)
   movwf     TBLPTRH
   movlw     low       (ST)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_5
set6
   movlw     upper     (TP) ;
   movwf     TBLPTRU
   movlw     high      (TP)
   movwf     TBLPTRH
   movlw     low       (TP)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_6
set7
   movlw     upper     (P1) ;
   movwf     TBLPTRU
   movlw     high      (P1)
   movwf     TBLPTRH
   movlw     low       (P1)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_7
set8
   movlw     upper     (P2) ;
   movwf     TBLPTRU
   movlw     high      (P2)
   movwf     TBLPTRH
   movlw     low       (P2)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_8
set9
   movlw     upper     (DM1) ;
   movwf     TBLPTRU
   movlw     high      (DM1)
   movwf     TBLPTRH
   movlw     low       (DM1)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_9
set10
   movlw     upper     (DM2) ;
   movwf     TBLPTRU
   movlw     high      (DM2)
   movwf     TBLPTRH
   movlw     low       (DM2)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_10
set11
   movlw     upper     (RR) ;
   movwf     TBLPTRU
   movlw     high      (RR)
   movwf     TBLPTRH
   movlw     low       (RR)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_11
set12
   movlw     upper     (QP) ;
   movwf     TBLPTRU
   movlw     high      (QP)
   movwf     TBLPTRH
   movlw     low       (QP)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_12
set13
   movlw     upper     (CXL) ;
   movwf     TBLPTRU
   movlw     high      (CXL)
   movwf     TBLPTRH
   movlw     low       (CXL)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_13
set14
   movlw     upper     (U1S) ;
   movwf     TBLPTRU
   movlw     high      (U1S)
   movwf     TBLPTRH
   movlw     low       (U1S)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_14
set15
   movlw     upper     (U2S) ;
   movwf     TBLPTRU
   movlw     high      (U2S)
   movwf     TBLPTRH
   movlw     low       (U2S)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_15
set16
   movlw     upper     (U3S) ;
   movwf     TBLPTRU
   movlw     high      (U3S)
   movwf     TBLPTRH
   movlw     low       (U3S)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_16
set17
   movlw     upper     (SP) ;
   movwf     TBLPTRU
   movlw     high      (SP)
   movwf     TBLPTRH
   movlw     low       (SP)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_17
set18
   movlw     upper     (DEBUG) ;
   movwf     TBLPTRU
   movlw     high      (DEBUG)
   movwf     TBLPTRH
   movlw     low       (DEBUG)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_18
set19
   movlw     upper     (EEP) ;
   movwf     TBLPTRU
   movlw     high      (EEP)
   movwf     TBLPTRH
   movlw     low       (EEP)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_19
set20
   movlw     upper     (SU) ;
   movwf     TBLPTRU
   movlw     high      (SU)
   movwf     TBLPTRH
   movlw     low       (SU)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper_Tlink_20
set21
   movlw     upper     (YS)
   movwf     TBLPTRU
   movlw     high      (YS)
   movwf     TBLPTRH
   movlw     low       (YS)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__1
set22
   movlw     upper     (CC)
   movwf     TBLPTRU
   movlw     high      (CC)
   movwf     TBLPTRH
   movlw     low       (CC)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__2
set23
   movlw     upper     (NF)
   movwf     TBLPTRU
   movlw     high      (NF)
   movwf     TBLPTRH
   movlw     low       (NF)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__3
set24
   movlw     upper     (TA)
   movwf     TBLPTRU
   movlw     high      (TA)
   movwf     TBLPTRH
   movlw     low       (TA)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__4
set25
   movlw     upper     (CDATA) ;
   movwf     TBLPTRU
   movlw     high      (CDATA)
   movwf     TBLPTRH
   movlw     low       (CDATA)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__5
set26
   movlw     upper     (SED) ;
   movwf     TBLPTRU
   movlw     high      (SED)
   movwf     TBLPTRH
   movlw     low       (SED)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__6
set27
   movlw     upper     (R1) ;
   movwf     TBLPTRU
   movlw     high      (R1)
   movwf     TBLPTRH
   movlw     low       (R1)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__7
set28
   movlw     upper     (S2) ;
   movwf     TBLPTRU
   movlw     high      (S2)
   movwf     TBLPTRH
   movlw     low       (S2)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__8
set29
   movlw     upper     (CW) ;
   movwf     TBLPTRU
   movlw     high      (CW)
   movwf     TBLPTRH
   movlw     low       (CW)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__9
set30
   movlw     upper     (EXIT) ;
   movwf     TBLPTRU
   movlw     high      (EXIT)
   movwf     TBLPTRH
   movlw     low       (EXIT)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__10
set31
   movlw     upper     (SRR) ;
   movwf     TBLPTRU
   movlw     high      (SRR)
   movwf     TBLPTRH
   movlw     low       (SRR)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__11
set32
   movlw     upper     (SV1) ;
   movwf     TBLPTRU
   movlw     high      (SV1)
   movwf     TBLPTRH
   movlw     low       (SV1)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__12
set33
   movlw     upper     (SV2) ;
   movwf     TBLPTRU
   movlw     high      (SV2)
   movwf     TBLPTRH
   movlw     low       (SV2)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__13
set34
   movlw     upper     (SV3) ;
   movwf     TBLPTRU
   movlw     high      (SV3)
   movwf     TBLPTRH
   movlw     low       (SV3)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__14
set35
   movlw     upper     (SV4) ;
   movwf     TBLPTRU
   movlw     high      (SV4)
   movwf     TBLPTRH
   movlw     low       (SV4)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__15
set36
   movlw     upper     (RASV) ;
   movwf     TBLPTRU
   movlw     high      (RASV)
   movwf     TBLPTRH
   movlw     low       (RASV)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__16
set37
   movlw     upper     (SDD) ;
   movwf     TBLPTRU
   movlw     high      (SDD)
   movwf     TBLPTRH
   movlw     low       (SDD)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__17
set38
   movlw     upper     (PPG) ;
   movwf     TBLPTRU
   movlw     high      (PPG)
   movwf     TBLPTRH
   movlw     low       (PPG)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__18
set39
   movlw     upper     (EEV) ;
   movwf     TBLPTRU
   movlw     high      (EEV)
   movwf     TBLPTRH
   movlw     low       (EEV)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__19
set40
   movlw     upper     (PU) ;
   movwf     TBLPTRU
   movlw     high      (PU)
   movwf     TBLPTRH
   movlw     low       (PU)
   movwf     TBLPTRL
   call      unpackdata
   goto      Hyper__20
   return;
unpackdata
   bz        Newpointer
sentdatapack
Newpointer
   movlw     b'10000000';
   movwf     PORTB
   goto      Hyper_Tlink_1
Hyper_Tlink_2;Entry Mode
   movlw     b'01000000';
   movwf     PORTB
   goto      Hyper_Tlink_2
Hyper_Tlink_3;
   movlw     b'00100000';
   movwf     PORTB
   goto      Hyper_Tlink_3
Hyper_Tlink_4;Adjusting setting
   ;banksel PORTB
   movlw     b'00010000';
   movwf     PORTB
   goto      Hyper_Tlink_4
Hyper_Tlink_5;
Hyper_Tlink_6;
Hyper_Tlink_7;
Hyper_Tlink_8;
Hyper_Tlink_9;
Hyper_Tlink_10;
Hyper_Tlink_11;
Hyper_Tlink_12;
Hyper_Tlink_13;
Hyper_Tlink_14;
Hyper_Tlink_15;
Hyper_Tlink_16;
Hyper_Tlink_17;
Hyper_Tlink_18;
Hyper_Tlink_19;   EEprom write
Hyper_Tlink_20;
;0000000000000000000000000000000000000000000
Hyper__1
Hyper__2
Hyper__3
Hyper__4
Hyper__5
Hyper__6
Hyper__7
Hyper__8
Hyper__9
Hyper__10
Hyper__11
Hyper__12
Hyper__13
Hyper__14
Hyper__15
Hyper__16
Hyper__17
Hyper__18
Hyper__19
Hyper__20
   end
Dimebag
Re: Subroutine problem with PIC18F452
Postby ric » Sun Jun 29, 2014 9:35 am
After you call the "request" subroutine, you fall straight into the same routine.
test_receive
   btfss   PIR1,RCIF   ;
   goto   test_receive
   movf   RCREG,w   ;
   call    request   ;
request
I think you may have intended to put a "goto test_receive" after the "call request".
Postby Dimebag » Sun Jun 29, 2014 10:24 am
Thanks Ric,
I was thinking its this part of the code.
 bz        Newpointer
There part code of
unpackdata
   bz        Newpointer
WREG appears to show 0x00 and BZ bounces to Newpointer and heads straight for the next sub. I had already tried what you suggested but nothing happens. For some reason I don't think I should be using (movwf TXREG)
Dimebag
Postby ric » Sun Jun 29, 2014 11:00 am
What is meant to happen when you go to Newpointer?
Right now it falls into Hyper_Tlink_1
Postby Dimebag » Sun Jun 29, 2014 11:24 am
It is meant to goto the following subroutines to carry out further instructions. All the Labels are meant to be able to be accessed via the serial port with letter assignments. I am not sure I answered your question Ric. I am not sure if testing TXREG is the best practice in this case.
Hyper_Tlink_1;
Hyper_Tlink_2;
Hyper_Tlink_3;
Hyper_Tlink_4;
Hyper_Tlink_5;
Hyper_Tlink_6;
Hyper_Tlink_7;
Hyper_Tlink_8;
Hyper_Tlink_9;
Hyper_Tlink_10;
Hyper_Tlink_11;
Hyper_Tlink_12;
Hyper_Tlink_13;
Hyper_Tlink_14;
Hyper_Tlink_15;
Hyper_Tlink_16;
Hyper_Tlink_17;
Hyper_Tlink_18;
Hyper_Tlink_19;
Hyper_Tlink_20;
Dimebag
Postby ric » Sun Jun 29, 2014 1:26 pm
Dimebag wrote:It is meant to goto the following subroutines to carry out further instructions. All the Labels are meant to be able to be accessed via the serial port with letter assignments. I am not sure I answered your question Ric. I am not sure if testing TXREG is the best practice in this case.
The bit of code that writes to TXREG is the only bit of your code that I think will work as intended.
Everything else is messy and unfinished.
You don't seem to understand either of the problems that I have pointed out, both of which mean your program flow cannot work as intended.
Postby Dimebag » Sun Jun 29, 2014 1:57 pm
0802    0009     TBLRD*+                        876:      TBLRD*+                       ;read table byte, advance to next
  0804    50F5     MOVF 0xff5, W, ACCESS          877:      movf      TABLAT,W            ;get the table byte
  0806    E009     BZ 0x81a                       878:      bz        Newpointer
  0808    6EAD     MOVWF 0xfad, ACCESS            879:      movwf     TXREG               ;save it in TXREG
  080A    EC09     CALL 0x812, 0                  880:      call      sentdatapack        ;make sure TXIF is set
  080C    F004     NOP
  080E    EF01     GOTO 0x802                     881:      goto      unpackdata         ;send next byte
  0810    F004     NOP
                                                  882:
                                                  883:
                                                  884:   sentdatapack
                                                  885:
  0812    A89E     BTFSS 0xf9e, 0x4, ACCESS       886:      btfss     PIR1, TXIF          ;has the byte been sent
  0814    EF09     GOTO 0x812                     887:      goto      sentdatapack        ;no, do it again
  0816    F004     NOP
                                                  888:   ;   goto test_receive
  0818    0012     RETURN 0                       889:      return    ;yes, finished.
                                                  890:
                                                  891:   Newpointer
                                                  892:
                                                  893:
                                                  894:
                                                  895:   ;$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
                                                  896:   Hyper_Tlink_1;Program Mode
  081A    0E80     MOVLW 0x80                     897:      movlw     b'10000000';
  081C    6E81     MOVWF 0xf81, ACCESS            898:      movwf     PORTB
  081E    EF0D     GOTO 0x81a                     899:      goto      Hyper_Tlink_1
  0820    F004     NOP
Indeed Ric. How would you suggest I resolve this problem? Disassembly code above
Dimebag
Postby ric » Sun Jun 29, 2014 2:00 pm
Which problem are you referring to now?
The problem in the code you are showing is that YOU have not put any code after the Newpointer label.
My guess is you actually want a return statement there, but it is better if you tell me what you want to happen straight after it jumps to Newpointer.
Postby Dimebag » Sun Jun 29, 2014 2:02 pm
Disassembly code. True it is...How do I fix this
Dimebag
Postby Dimebag » Sun Jun 29, 2014 2:05 pm
(Edit Start)
Hi Ric sorry I edited this post. The Label you are speaking of has been a pain. Would you be so kind to help me improve it for testing application.
(Edit End)
I would like code to select the subroutine via serial characters.
Dimebag
