Trouble using RC2 as input on PIC18F24K22
Postby AJ52486 » Wed Feb 25, 2015 12:53 am
I have push-button switches connected to RC0, RC1 and RC2 on a PIC18F24K22. The switches are normally low, but go high when pressed.
I am able to detect RC0 and RC1 as high when their switches are pressed. RC2 is always detected as low in software, even when its switch is pressed. I have confirmed that the physical pin for RC2 is at 5v when the switch is pressed.
I have cleared ANSELC and set bits 0-2 in TRISC.
I tried a second PIC18F24K22, but had the same results.
RC2 is shared with CCP1, P1A, CTPLS and T5CKI. I have cleared CCP1CON, the CTMUEN and EDGEN bits in CTMUCONH, the TMR5ON bit in T5CON and the TMR5GE bit in T5GCON.
I still couldn't detect RC2 going high in software, so I cleared bit TMR5MD in PMD0, bit CCP1MD in PMD1 and bit CTMUMD in PMD2.
The code is shown below. There was much more there, but I commented most of it out to try to resolve this issue. I excluded the commented code. I placed a breakpoint on each of the 3 "GOTO BtnEnd" lines to detect when the switches are pressed. The program halts when the switch on RC0 or RC1 is pressed, but not when the switch on RC2 is pressed.
Thanks in advance for any advice that you can give me.
-Andrew
;    Filename:        *
;    Date:        *
;    File Version:                                                             *
;    Author:        *
;    Company:        *
;    Description:                                                              *
;    Notes: In the MPLAB X Help, refer to the MPASM Assembler documentation    *
;    for information on assembly instructions.                                 *
;    Known Issues: This template is designed for relocatable code.  As such,   *
;    build errors such as "Directive only allowed when generating an object    *
;    file" will result when the 'Build in Absolute Mode' checkbox is selected  *
;    in the project properties.  Designing code in absolute mode is            *
;    antiquated - use relocatable mode.                                        *
;    Revision History:                                                         *
; Processor Inclusion
; TODO Step #1 Open the task list under Window > Tasks.  Include your
; device .inc file - e.g. #include <device_name>.inc.  Available
; include files are in C:\Program Files\Microchip\MPLABX\mpasmx
; assuming the default installation path for MPLAB X.  You may manually find
; the appropriate include file for your device here and include it, or
; simply copy the include generated by the configuration bits
; generator (see Step #2).
#include <p18f24k22.inc>
; TODO Step #2 - Configuration Word Setup
; The 'CONFIG' directive is used to embed the configuration word within the
; .asm file. MPLAB X requires users to embed their configuration words
; into source code.  See the device datasheet for additional information
; on configuration word settings.  Device configuration bits descriptions
; are in C:\Program Files\Microchip\MPLABX\mpasmx\P<device_name>.inc
; (may change depending on your MPLAB X installation directory).
; MPLAB X has a feature which generates configuration bits source code.  Go to
; Window > PIC Memory Views > Configuration Bits.  Configure each field as
; needed and select 'Generate Source Code to Output'.  The resulting code which
; appears in the 'Output Window' > 'Config Bits Source' tab may be copied
; below.
; CONFIG1H
  CONFIG  FOSC = INTIO67        ; Oscillator Selection bits (Internal oscillator block)
  CONFIG  PLLCFG = OFF          ; 4X PLL Enable (Oscillator used directly)
  CONFIG  PRICLKEN = ON         ; Primary clock enable bit (Primary clock enabled)
  CONFIG  FCMEN = OFF           ; Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
  CONFIG  IESO = OFF            ; Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
; CONFIG2L
  CONFIG  PWRTEN = ON           ; Power-up Timer Enable bit (Power up timer enabled)
  CONFIG  BOREN = SBORDIS       ; Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
  CONFIG  BORV = 190            ; Brown Out Reset Voltage bits (VBOR set to 1.90 V nominal)
; CONFIG2H
  CONFIG  WDTEN = OFF           ; Watchdog Timer Enable bits (Watch dog timer is always disabled. SWDTEN has no effect.)
  CONFIG  WDTPS = 32768         ; Watchdog Timer Postscale Select bits (1:32768)
; CONFIG3H
  CONFIG  CCP2MX = PORTC1       ; CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
  CONFIG  PBADEN = ON           ; PORTB A/D Enable bit (PORTB<5:0> pins are configured as analog input channels on Reset)
  CONFIG  CCP3MX = PORTB5       ; P3A/CCP3 Mux bit (P3A/CCP3 input/output is multiplexed with RB5)
  CONFIG  HFOFST = ON           ; HFINTOSC Fast Start-up (HFINTOSC output and ready status are not delayed by the oscillator stable status)
  CONFIG  T3CMX = PORTC0        ; Timer3 Clock input mux bit (T3CKI is on RC0)
  CONFIG  P2BMX = PORTB5        ; ECCP2 B output mux bit (P2B is on RB5)
  CONFIG  MCLRE = EXTMCLR       ; MCLR Pin Enable bit (MCLR pin enabled, RE3 input pin disabled)
; CONFIG4L
  CONFIG  STVREN = ON           ; Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
  CONFIG  LVP = OFF             ; Single-Supply ICSP Enable bit (Single-Supply ICSP enabled if MCLRE is also 1)
  CONFIG  XINST = OFF           ; Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
; CONFIG5L
  CONFIG  CP0 = OFF             ; Code Protection Block 0 (Block 0 (000800-001FFFh) not code-protected)
  CONFIG  CP1 = OFF             ; Code Protection Block 1 (Block 1 (002000-003FFFh) not code-protected)
; CONFIG5H
  CONFIG  CPB = OFF             ; Boot Block Code Protection bit (Boot block (000000-0007FFh) not code-protected)
  CONFIG  CPD = OFF             ; Data EEPROM Code Protection bit (Data EEPROM not code-protected)
; CONFIG6L
  CONFIG  WRT0 = OFF            ; Write Protection Block 0 (Block 0 (000800-001FFFh) not write-protected)
  CONFIG  WRT1 = OFF            ; Write Protection Block 1 (Block 1 (002000-003FFFh) not write-protected)
; CONFIG6H
  CONFIG  WRTC = OFF            ; Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
  CONFIG  WRTB = OFF            ; Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
  CONFIG  WRTD = OFF            ; Data EEPROM Write Protection bit (Data EEPROM not write-protected)
; CONFIG7L
  CONFIG  EBTR0 = OFF           ; Table Read Protection Block 0 (Block 0 (000800-001FFFh) not protected from table reads executed in other blocks)
  CONFIG  EBTR1 = OFF           ; Table Read Protection Block 1 (Block 1 (002000-003FFFh) not protected from table reads executed in other blocks)
; CONFIG7H
  CONFIG  EBTRB = OFF           ; Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
; TODO Step #3 - Variable Definitions
; Refer to datasheet for available data memory (RAM) organization assuming
; relocatible code organization (which is an option in project
; properties > mpasm (Global Options)).  Absolute mode generally should
; be used sparingly.
; Example of using GPR Uninitialized Data
;   GPR_VAR        UDATA
;   MYVAR1         RES        1      ; User variable linker places
;   MYVAR2         RES        1      ; User variable linker places
;   MYVAR3         RES        1      ; User variable linker places
;   ; Example of using Access Uninitialized Data Section (when available)
;   ; The variables for the context saving in the device datasheet may need
;   ; memory reserved here.
;   INT_VAR        UDATA_ACS
;   W_TEMP         RES        1      ; w register for context saving (ACCESS)
;   STATUS_TEMP    RES        1      ; status used for context saving
;   BSR_TEMP       RES        1      ; bank select used for ISR context saving
        UDATA
ADCvalue        RES 2
MainTemp        RES 2
MainTempSP      RES 2
ElementTemp     RES 2
ElementTempSP   RES 2
BCDvalH         RES 1
BCDvalM         RES 1
BCDvalL         RES 1
MCount          RES 1
NumbHi          RES 1
NumbLo          RES 1
Temp            RES 2
Flags           RES 1
ErrorValue      RES 1
DigitSelected   RES 1
DisplayValue    RES 2
SPDisplayValue  RES 2
DispValFlags    RES 1
BtnLockoutCount RES 1
SPSetCount      RES 1
Augend          RES 2
Addend          RES 2
Subtrahend      RES 2
Minuend         RES 2
BCDSubFlags     RES 1
TableOffset     RES 1
#define RelayPin PORTC,RC3
#define DisplayPort PORTA
#define DigitSelectPort PORTC
#define Digit1 PORTC,RC7
#define Digit2 PORTC,RC6
#define Digit3 PORTC,RC5
#define Digit4 PORTC,RC4
#define ModeLED PORTB,RB3
#define ErrorLED PORTB,RB4
#define StatusLED PORTB,RB5
#define ModeBtn PORTC,RC0
#define UpBtn PORTC,RC1
#define DownBtn PORTC,RC2
#define FloatSwitch PORTB,RB2
#define MainTempSensor PORTB,AN12
#define MainTempSensorAnalog ANSELB,AN12
#define ElementTempSensor PORTB,AN10
#define ElementTempSensorAnalog ANSELB,AN10
#define ConvertADCValuePtrL H'00'
#define ConvertADCValuePtrH H'04'
#define ConvertADCValuePtrU H'00'
#define DefaultMainTempL H'50'
#define DefaultMainTempH H'08'
#define DefaultElementTempL H'00'
#define DefaultElementTempH H'12'
#define MainTempEEADR H'4'
#define ElementTempEEADR H'6'
#define Mode H'0'                               ; 0=Thermometer, 1=Thermostat
#define DisplayMode H'1'                        ; 0=Display Temperature, 1=Display Set-Point
#define AdjustSetPoint H'2'                     ; 0=Main Temp., 1=Element Temp.
#define TemperatureDisplay H'3'                 ; 0=Main Temp., 1=Element Temp.
#define ModeBtnLockout H'4'                     ; 0=Disabled, 1=Enabled
#define UpBtnLockout H'5'                       ; 0=Disabled, 1=Enabled
#define DownBtnLockout H'6'                     ; 0=Disabled, 1=Enabled
#define SPSetExpired H'7'                       ; 0=False, 1=True
#define DigitSelectMask B'00001111'             ; 0=Bit to clear, 1=Bit to remain unchanged
#define LowDigitCarry H'0'                      ; Digit Carry from low byte of DisplayValue
#define LowCarry H'1'                           ; Carry from low byte of DisplayValue
#define HighDigitCarry H'2'                     ; Digit Carry from high byte of DisplayValue
; Reset Vector
RES_VECT  CODE    0x0000            ; processor reset vector
    GOTO    START                   ; go to beginning of program
; TODO Step #4 - Interrupt Service Routines
; There are a few different ways to structure interrupt routines in the 8
; bit device families.  On PIC18's the high priority and low priority
; interrupts are located at 0x0008 and 0x0018, respectively.  On PIC16's and
; lower the interrupt is at 0x0004.  Between device families there is subtle
; variation in the both the hardware supporting the ISR (for restoring
; interrupt context) as well as the software used to restore the context
; (without corrupting the STATUS bits).
; General formats are shown below in relocatible format.
;------------------------------PIC16's and below--------------------------------
; ISR       CODE    0x0004           ; interrupt vector location
;     <Search the device datasheet for 'context' and copy interrupt
;     context saving code here.  Older devices need context saving code,
;     but newer devices like the 16F#### don't need context saving code.>
;     RETFIE
;----------------------------------PIC18's--------------------------------------
; ISRHV     CODE    0x0008
;     GOTO    HIGH_ISR
; ISRLV     CODE    0x0018
;     GOTO    LOW_ISR
; ISRH      CODE                     ; let linker place high ISR routine
; HIGH_ISR
;     <Insert High Priority ISR Here - no SW context saving>
;     RETFIE  FAST
; ISRL      CODE                     ; let linker place low ISR routine
; LOW_ISR
;       context saving code here>
;     RETFIE
ISRHV     CODE    0x0008
    GOTO    HIGH_ISR
;ISRLV     CODE    0x0018
;    GOTO    LOW_ISR
HIGH_ISR
    BCF     INTCON,TMR0IF                   ; Clear Timer0 Interrupt Flag
    RETFIE  FAST
; MAIN PROGRAM
MAIN_PROG CODE                          ; let linker place main program
START
    ; Initialize Variables
    CLRF    Flags
    ; Set up Digital Pins
    CLRF    PORTA
    CLRF    ANSELA
    CLRF    PORTB
    CLRF    ANSELB
    CLRF    PORTC
    CLRF    ANSELC
    CLRF    TRISA
    MOVLW   B'00000111'
    MOVWF   TRISB
    MOVLW   B'00000111'
    MOVWF   TRISC
    MOVLW   B'10000000'
    MOVWF   DigitSelected
    CLRF    CCP1CON
    CLRF    CCP2CON
    CLRF    CCP3CON
    BCF     CTMUCONH,CTMUEN
    BCF     CTMUCONH,EDGEN
    BCF     T5CON,TMR5ON
    BCF     T5GCON,TMR5GE
    BCF     PMD0,TMR5MD
    BCF     PMD1,CCP1MD
    BCF     PMD2,CTMUMD
    MOVLW   B'00000111'
    MOVWF   TRISC
MAIN
    BTFSC   ModeBtn
    GOTO    BtnEnd
    BTFSC   UpBtn
    GOTO    BtnEnd
    BTFSC   DownBtn
    GOTO    BtnEnd
BtnEnd
    GOTO MAIN
END
AJ52486
Re: Trouble using RC2 as input on PIC18F24K22
Postby ric » Wed Feb 25, 2015 5:28 am
If you are using a debugger, what do you see if you watch PORTC?
Postby vloki » Wed Feb 25, 2015 8:56 am
AJ52486 wrote:I am able to detect RC0 and RC1 as high when their switches are pressed. RC2 is always detected as low in software, even when its switch is pressed. I have confirmed that the physical pin for RC2 is at 5v when the switch is pressed.
ANSELx registers are not located in the access bank.
(RC0, RC1 do not have analog features ;-)
EXAMPLE 10-3: INITIALIZING PORTC
MOVLB 0xF ; Set BSR for banked SFRs
CLRF PORTC ; Initialize PORTC by
; clearing output
; data latches
CLRF LATC ; Alternate method
; to clear output
; data latches
MOVLW 0CFh ; Value used to
; initialize data
; direction
MOVWF TRISC ; Set RC<3:0> as inputs
; RC<5:4> as outputs
; RC<7:6> as inputs
MOVLW 30h ; Value used to
; enable digital inputs
MOVWF ANSELC ; RC<3:2> dig input enable
; No ANSEL bits for RC<1:0>
; RC<7:6> dig input enable
Postby AJ52486 » Thu Feb 26, 2015 4:34 am
ric, I could see bits 1:0 changing to 1, but bit 2 was always 0.
vloki, I glanced right over the BSR section and the MOVLB command. I haven't had a chance to try this yet, but it seems like the solution.
So if I'm trying to access the Access Bank, which is 000h to 05Fh and F60h to FFFh, I should clear the BSR? If I need to access something outside of the Access Bank, I set the 4 lower bits of BSR to the 4 upper bits of the address that I want to access?
If I use a command that accepts the 'a' operand, but I don't supply a value for 'a', does it default to 1, which uses the BSR?
Thanks,
Andrew
AJ52486
Postby vloki » Thu Feb 26, 2015 8:31 am
Sorry, I rarely code in assembly these days - So I may be wrong with the following ;-)
The assembler/linker seems to know whether a register is in banked or access RAM and adds the correct 'a' operand for you.
If a register is in access RAM and the corresponding 'a' is used, then the BSR is simply not used and there is no need to do anything in this case.
The BSR is only important if the register is in banked RAM. Then you have to set it to the correct bank. Usually you do that with the banksel directive.
(See the assembler/linker user's guide for more ...)
Postby AJ52486 » Fri Feb 27, 2015 2:11 am
vloki, using BANKSEL to set the BSR solved my issue.
I still don't fully understand how to implement bank selection. It seems that there is a bit of magic involved during assembly. I think I'll just use a MOVLB H'0' after I'm done with the registers that are not in the Access Bank.
Thanks!
AJ52486
