PIC 18F4550 serial communications with VB
I wrote a simple program in VB to communicate with my microcontroller (18F4550) via serial external (UART cp201) just to turn on four leds and then turn them off manually.
ric helped out on some of the code but am stuck at a compile error: "unable to resolve identifier "RCIF"
Using MPLABX and XC8 compiler.
xc.h is in my header file VB-LED.h
If someone has any ideas, will be much appreciated!
BTW- the 18f4550 is 8 bit correct?
#include <stdio.h>
#include <stdlib.h>
#include "VB-LED.h"
void main (void)
TRISDbits.RD0 = 0; //set portD bit 0 as output for pin RD0
TRISDbits.RD1 = 0; //set portD bit 0 as output for pin RD1
TRISDbits.RD4 = 0; //set portD bit 0 as output for pin RD4
TRISDbits.RD5 = 0; //set portD bit 0 as output for pin RD5
OSCCON = 0x70; //configure OSCCON register to internal oscilator
//check data sheet for this value
while (1)
//program loop
void config (void)
// USART configuration
TXSTAbits.TX9 = 0; // 8-bit transmission
TXSTAbits.TXEN = 1; // transmit enabled
TXSTAbits.SYNC = 0; // asynchronous mode
TXSTAbits.BRGH = 1; // high speed
RCSTAbits.SPEN = 1; // enable serial port (configures RX/DT and TX/CK pins as serial port pins)
RCSTAbits.RX9 = 0; // 8-bit reception
RCSTAbits.CREN = 1; // enable receiver
BAUDCONbits.BRG16 = 0; // 8-bit baud rate generator
SPBRG = 51; // "51" calculated using formula from table 20-1 in the PIC18F4550 datasheet
// 8MHz and 9600 baud for Asynchronous, BRGH=1 "high speed"
TRISCbits.RC6 = 0; // make the TX pin a digital output
TRISCbits.RC7 = 1; // make the RX pin a digital input
while (PIR1.RCIF == 0); //wait until a character arrives
unsigned char buf = RCREG; //read and save the character from the USART
switch (buf)
case 'W':
LATDbits.LATD0 = 1; //1= ON for pin RD0
break;
case 'R':
LATDbits.LATD1 = 1; //1= ON for pin RD1
break;
case 'G':
LATDbits.LATD4 = 1; //1= ON for pin RD4
break;
case 'Y':
LATDbits.LATD5 = 1; //1= ON for pin RD5
break;
case 'S':
PORTD = 0; // 0= OFF for all pins port D
break;
} //end of "switch()" statement
