Device configuration
Re: Device configuration
Postby Dimebag » Sun Jul 27, 2014 8:41 am
I couldn't get __delay_ms() to work, so I made my own 1 second delay.
void delay1second(void) {
    int DelaySec = 9174; //9174
    //999.994ms
    int Delay1Sec = 6; //6
      for (inside = 0; inside < DelaySec; inside++) {
        for (outside = 0; outside < Delay1Sec; outside++) {
    Initialization(); //Set all device pins.
    while (1) {
        delay1ms();
        PORTD = 0x01; // array[0];
        delay1ms();
        PORTD = 0x00;
Dimebag
Postby ric » Sun Jul 27, 2014 9:14 am
What problem did you have with __delay_ms() ?
Note, your routine will change delay, depending upon which optimisation level the compiler is using, and is even liable to get optimised away completely if the innermost count variable isn't declared "volatile".
Postby Dimebag » Sun Jul 27, 2014 10:30 am
Well I don't know how use it with mplabx. I tried to use it weeks ago, I discovered that it didn't matter the delay_ms(5000) I added it did the same stopwatch cycles. I decided to make my own due to not getting anywhere with __delay_ms(). It is very difficult to explain a problem if I don't know the problem to start with. I am trying, just very frustrating atm.
Dimebag
Postby ric » Sun Jul 27, 2014 10:42 am
Dimebag wrote:Well I don't know how use it with mplabx.
MPLABX is just the editing environment. It is the compiler that matters.
I can't work out what you are saying here.
Just ask. Don't give vague explanations of what you did, show the actual code, and say what happened.
Postby Dimebag » Sun Jul 27, 2014 10:59 am
Break point at line 92 in file D:/MPLABXProjects/Blinker.X/BlinkLED.c cannot be resolved to a valid program memory address
#define __delay_ms;
#define XTAL_FREQ = 20000000;
and
    while (1) {
        __delay_ms(1000);
        __delay_ms(5000);
        PORTD = 0x00;
Dimebag
Postby ric » Sun Jul 27, 2014 11:33 am
Remove the
#define __delay_ms;
line.
There is a bug in the MPLABX editor, which puts a red squiggle under __delay_ms() when you use it, but it compiles fine.
Using that #define to get rid of the squiggle actually removes the real call to the function.
Postby Dimebag » Sun Jul 27, 2014 1:10 pm
so,
XTAL_FREQ = xxx should work if only the function/macro is called. __delay_ms() should be available to mplabx user to set clock speed with TCY1. I am trying to understand Rick. I have tried to get the Macro...I just missed something to get it to work.
Dimebag
Postby ric » Sun Jul 27, 2014 1:20 pm
Dimebag wrote:so,
__delay_ms() is actually a macro defined by the compiler, and it uses the XTAL_FREQ definition as part of its calculations to get the correct delay.
I have no idea what you are trying to say here.
I don't know why you are still referring to MPLABX. It is the compiler (Hitech C, XC8, whatever) that is providing this function. MPLABX is just the editor.
Have you removed the line I asked you to, and tried it? It should just work.
Postby Dimebag » Sun Jul 27, 2014 1:38 pm
I am back to square one again. I don't use HITECH complier Rick. I must have missed some important parts of the mplabx complier files. You are teaching me what to do, its just not working as it should.
Dimebag
Postby ric » Sun Jul 27, 2014 1:42 pm
What are you using?
MPLABX is not a compiler. You must have some compiler installed if you're writing in C.
You mentioned XC8 back on page 1.
I said "HiTech C, XC8, whatever)".
The __wait_ms() macro is available in both, as XC8 is just a development from HiTech C.
Users browsing this forum: Google [Bot] and 23 guests
