Reading PORTB to Terminal
Re: Reading PORTB to Terminal
Postby GettinBetter » Sun Jul 28, 2019 7:08 am
Setup:
EasyPIC V7 board/ICD3/MCC
Using PIC18F45K22/8MHz or 20MHz
XC8/C90.
Whoa! Really ..it's that simple?
Ok, that's fantastic...I'll setup the encoder on my dev board today, and have a go over the coming days.
Incidentally the encoder is an Autonics EP50S8-1024-3F-P-24, & I'll be attempting to run two of them plus two PWM's for the motors from a Bosch BNO055.
Does that mean I have to create the lookup table similar to the Bournes encoder, not that I mind, I'm just thinking of available memory & speed to access that table each time.
https://res.cloudinary.com/iwh/image/upload/q_auto,g_center/assets/1/26/Autonics_Rotary_Encoder_EP50S_Series_Data_Sheet.pdf
https://www.bosch-sensortec.com/bst/products/all_products/bno055
Les
GettinBetter
Postby ric » Sun Jul 28, 2019 8:59 am
The EP50S8-1024-3F-P-24 outputs 1024 states as a 10 bit gray code.
If you had a EP50S8-1024-2F-P-24 instead, it would output the binary position directly.
You can google "convert gray code to binary" there are a number of code algorithms to do it.
Postby GettinBetter » Sun Jul 28, 2019 10:06 am
Ah crap, oh well, I'll have to put that one down to experience...don't fancy buying them again, they were quite expensive, maybe for the next model... but well spotted.
Yes, I've been at it since I last posted....lots of stuff for C# & C++ ....but I'm sure it's out there.. might just look for the XOR concept ... I'll see how the weekend goes searching.. thanks again for your input.
Les
GettinBetter
Postby ric » Sun Jul 28, 2019 10:14 am
Note, there is a good reason why encoders commonly use gray code.
It is designed so that only one bit ever changes from one state to the next, so you can't get an invalid value right on the transition.
(e.g. if one bit changes at a fractionally different time to another bit)
See: https://en.wikipedia.org/wiki/Gray_code
Users browsing this forum: No registered users and 24 guests
