Bootloader in a dsPIC33CH dual core
Postby ivanalad » Thu Aug 10, 2023 2:02 pm
Hi Guys,
I am using a dsPIC33CH512MP508 in DUAL core mode and it works fine when I flash the chip without Bootloader (Using the ICSP)
Now, I am trying to implement a Bootloader + my dual core application.
Following the instructions from "https://www.microchip.com/en-us/software-library/dspic33-pic24-bootloader", I managed to integrate a bootloader in my dsPIC33 and also program the application using the "Unified Bootloader Host Application" (loading the hex file from my main/master project).
The problem is that the slave core does not work, I was trying to receive some messages from the slave core using the message box system between cores and the slave core does not do anything (not response), however, if I ignore the slave core in the "main" doing other functions, the master core works fine.
However, if I flash the pic directly with the hex file using MPLAB X IPE 5.50 (No bootloader) and the ICSP, both cores work fine and the code runs as "normal" (both cores do their work).
Questions:
- Because I used MCC for the bootloader configuration as a "Bootloader". Do I have to change anything if I am using DUAL core?
- For my main Application, do I have to change anything here?
- Am I missing anything related with the DUAL core configuration for the bootloader?
For your info, my main (master core code) starts as follow:
//MAIN
int main(void)
  // initialize the device
  SYSTEM_Initialize();
  RCONbits.SWDTEN = 0;  //Disabled the watchdog timer
  //Program and enable Slave Core
    SLAVE1_Program();
    SLAVE1_Start();
//Main code continues...
Thanks in advance.
KR,
Ivan
ivanalad
Users browsing this forum: No registered users and 63 guests
