Unstable PIC16F884
Hello -
I've made a simple LED flasher breadboard circuit using a 18F45K42, crystal osc with no issues. Switch to a PC16F884 leads to problems:
1) Oscillator is unstable. Stops oscillating when lay board flat on surface. Stray capacitance issue with 16F vs 18F?? Have to tilt the board!
2) Switch to internal oscillator sent OSCCOM to 0b0111000 for highest 8MHz operation. Get inconsistent results. Flash durations not related to __delay_ms() settings or _XTAL_FREQ settings. Initially I set to 8000000 (8MHz) tried all different delays and __XTAL_FREQ values.
Don't know why the 16F should be so unstable with crystal while the 18F is so robust. I've swapped out replacement PIC16F884's and crystals. Same issues. Don't understand response to internal oscillator commands.
Using XC8 MPlab Pickit3
Thanks!
Thanks!
