Timer1 running in SLEEP mode
Hi forum,
sorry I'm not often frequenting the forum.
I commonly use a 12F675, but one thing I never learned. Is the timer1 running when the MCU is in a sleep state ?
I mean, is the internal clock feeding the timer during sleep time ?
Anyways. With a different case I've try to fed the clock with a 32 kHz quartz. Everything is fine and shows the running time, but only when is not yet in a sleep state. Once the command is performed nothing comes back alive.
So I still not having much luck with low power projects
