TIMER1 intterupt of PIC 16f88
Hi;
I'm trying to work ultrasonic sensor (HCSR-04) with PIC16f88 since other interrutps (RB0 and INT0) were used I'm trying to opertare HCSR04 with Timer1.When I connected trigger and echo to oscillator everyting seems OK. I can see trigger and corresponding echo related with distance. I think interrupt never occurs When I read data sheet of microcontroller I understand as RB6 is related with TMR1 interrupt. Here is my code.
#define _XTAL_FREQ 8000000 // crystal freq defined as 8 Mhz
int b;
void main()
OSCCON = 0b01111000; // 8 Mhz selected Internal Oscillator Freq
INTCON = 0b11000000; // GIE and PEIE is enabled
TRISB = 0b01000000; // RB6 selected as input(echo connected here)
T1CON = 0b01001000; // System clock is derived from Timer1 oscillator with
// 1:1 prescale value and oscillator is enabled
PIE1bits.TMR1IE=1; // TMR1 overflow is enabled
ei(); // interrupt is enabled
while(1)
TMR1H = 0; //Setting Initial Value of Timer
TMR1L = 0; //Setting Initial Value of Timer
b = 0; // TMR1 value is taken in b (look at interrupt at below)
RB5=1;
__delay_us(10); //trigger is sent
RB5=0;
__delay_ms(100); //Waiting for ECHO
if(b>2 && b<=20) // If measured distance is between 2-20 cm led
// at RB1 blinks
RB1=1;
__delay_ms(500);
RB1=0;
if(b>20 ) // If measured distance is higher than 20 cm led at RB2 blinks
RB2=1;
__delay_ms(500);
RB2=0;
} // while closed
} // main closed
void interrupt echo()
if(PIR1bits.TMR1IF == 1) // Code enters if when flag condition occured
//PIE1bits.TMR1IE=0; // I also tried with that but it didn’t work
T1CONbits.TMR1ON = 1; //Start Timer
if(RB6 == 0) //If ECHO is LOW
T1CONbits.TMR1ON = 0; //Stop Timer
b = (TMR1L | (TMR1H<<8))/58; //Calculate Distance
PIR1bits.TMR1IF=0; //Clear PORTB OnChange Interrupt flag
//PIE1bits.TMR1IE=1; // Enable is opened if it is closed at top
