PIC12F1501, ADC not converting
Re: PIC12F1501, ADC not converting
Postby ric » Tue Jul 15, 2014 2:04 am
Please post your latest code.
Also, I would suggest initialising the ADC once, and leave it turned on for now. You're saving insignificant current by turning it off after every conversion.
Postby ksmes » Sat Jul 26, 2014 9:28 pm
Hi ric,
I stepped away for a while, vacation time. No computers allowed.
This is the latest code configuration for this project that started this post. I realize the ADC is not drawing much current so turning it on and off could be removed. Balancing the solar panel connection to the pin did take a bit to work out the loading, not for a voltage divider but for accurate conversions. It may only source 30 mA at 3.8 vdc at full sun.
The PIC12F1501, it's support components and the code are working very well at this time.
Still, I have a lot to learn.
Thanks,
Ken
     * File:   GarageDoorLights.c
     * Author: Ken
     * Created on June 28, 2014, 3:59 PM
    // PIC12F1501 Configuration Bit Settings
 #ifndef __PICCPRO__
 #define __PICCPRO__
 #endif
    // CONFIG1
    #pragma config FOSC = INTOSC    // Oscillator Selection Bits (INTOSC oscillator: I/O function on CLKIN pin)
    #pragma config WDTE = OFF       // Watchdog Timer Enable (WDT disabled)
    #pragma config PWRTE = ON       // Power-up Timer Enable (PWRT enabled)
    #pragma config MCLRE = OFF      // MCLR Pin Function Select (MCLR/VPP pin function is digital input)
    #pragma config CP = OFF         // Flash Program Memory Code Protection (Program memory code protection is disabled)
    #pragma config BOREN = ON       // Brown-out Reset Enable (Brown-out Reset enabled)
    #pragma config CLKOUTEN = OFF   // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
    // CONFIG2
    #pragma config WRT = OFF        // Flash Memory Self-Write Protection (Write protection off)
    #pragma config STVREN = OFF     // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will not cause a Reset)
    #pragma config BORV = HI        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), high trip point selected.)
    #pragma config LPBOR = ON       // Low-Power Brown Out Reset (Low-Power BOR is enabled)
    #pragma config LVP = ON         // Low-Voltage Programming Enable (Low-voltage programming enabled)
#define _XTAL_FREQ 16000000
#define FALSE (0)
#define TRUE (!0)
#define FRONT_DOOR_OPEN (PORTAbits.RA0 == 1)
#define FRONT_DOOR_CLOSE (PORTAbits.RA0 == 0)
#define BACK_DOOR_OPEN (PORTAbits.RA1 == 1)
#define BACK_DOOR_CLOSE (PORTAbits.RA1 == 0)
#define KITCHEN_DOOR_OPEN (PORTAbits.RA2 == 1)
#define KITCHEN_DOOR_CLOSE (PORTAbits.RA2 == 0)
//    #define LED_On (LATAbits.LATA5 = 1)
//    #define LED_Off (LATAbits.LATA5 = 0)
//    #define Green_LED_On (LATAbits.LATA4 = 1)
//    #define Green_LED_Off (LATAbits.LATA4 = 0)
char   LightOut     = 0;        // Sample of light from outside, used to decide if light out
char   LightTrip    = 0x38;     // Trip point 30. If the Light out is less than X value.
                                // This value is based on the output of the solar panel at
                                // a poit that additional light in the garage would be prefered.
char   Counter      = 0;        // Used to adjust the PWM output duration.
                                //  Long delay * Counter = Time that PWM is at max
char FrontJustOpened;
char BackJustOpened;
char KitchenJustOpened;
char FrontWasClosed = TRUE;
char BackWasClosed = TRUE;
char KitchenWasClosed = TRUE;
void WaitForDoorOpening();
void Dev_Init();
void Check_If_It_Is_Day_Or_Night();
void Cycle_The_Lights_Once();
void UpDelay();
void ShortDelay();
void LongDelay();
    void main()                //   The start of the entire functional program.
       Dev_Init();             //  Configures the device inputs and outputs.
        while(1)                //  Keep running in this loop.
            WaitForDoorOpening();  // leave this function only when you want the lights to come on.
// This will only exit when a door transitions from closed to
// opened, any door combination. Example - If all are closed and
// one door opens, the lights will turn on for one cycle. If the door is
// still open after the light cycle completes, the lights will turn
// off. Now if the door is still open and another one opens the lights
// will then cycle one more time.
int LightOnBySensor = FALSE;
   FrontJustOpened = FALSE;
   BackJustOpened = FALSE;
   KitchenJustOpened = FALSE;
     // the next 3 if statements simply will note that a door
     // has transitioned from closed to opened
   while(!FrontJustOpened &&    //  Checks if the doors just opened
         !BackJustOpened  &&    //  this instant.
         !KitchenJustOpened &&
         !LightOnBySensor
           )    //  Stay in loop till one opens.
    ShortDelay();      // waste some time
    if (FrontWasClosed)
        if (FRONT_DOOR_OPEN)        // was closed so lets see if it just opened.
           FrontJustOpened = TRUE;  // since just opened we will then go and turn on lights
           FrontWasClosed = FALSE;  // no longer closed.
    else if (FRONT_DOOR_CLOSE)  // Front door was opened but now closed
       ShortDelay();  // Debounce needed on close only since open has a 1.5 minute debounce
    else  // Front door is open so see if the sensor wants to turn on the lights
//        Room to add an optional sensor.
    if (BackWasClosed)
        if (BACK_DOOR_OPEN)
           BackJustOpened = TRUE;
           BackWasClosed = FALSE;
    else if (BACK_DOOR_CLOSE)  //
       ShortDelay();  // Debounce needed on close only since open has a 2 minute debounce
    if (KitchenWasClosed)
        if (KITCHEN_DOOR_OPEN)
           KitchenJustOpened = TRUE;
           KitchenWasClosed = FALSE;
    else if (KITCHEN_DOOR_CLOSE)  // door was opened but now closed
 }  // end of the while loop waiting for a door to open.
    void Dev_Init() // setup the OPTION_REG , Load with 0xD4
           OPTION_REG = 0x08;           //
           INTCON     = 0;              // Interups Off till needed.
           OSCCON     = 0x7A;           // Int RC Osc at 16 MHz, Int Osc is system CLK
           PORTA = 0x00;                // Clear PORTA
           LATA =  0x00;                // Clear LATA
           TRISA0 = 1;                  // Front Door Switch input active High.
           TRISA1 = 1;                  // Back Door Switch input active High.
           TRISA2 = 1;                  // Kitchen Door Switch input active High.
           TRISA3 = 1;                  // Dig Input, not used, MCLR.
           TRISA4 = 1;                  // Light Input. From Solar Panel
           TRISA5 = 0;                  // PWM output.
           ANSELA = 0x10;               // AN3 Only is On. This is RA4 on Pin 3.
        ADRESH = 0;                     // clear the last result
        ADCON1  =   0x60;               // ADRESH is Result, FOSC/64, Vref = VDD
        TRISAbits.TRISA4 = 1;           // RA4 is set for input
        ANSELAbits.ANSA4 = 1;           // RA4/AN3 set for Analog input
        ADCON0  = 0x0D;                 // Chan AN3 selected, Not in Progress, ADC Enabled
        __delay_ms(5);                  // Cap Charge time, may be a bit much
        ADCON0bits.GO = 1;              // Start the conversion
        while(ADCON0bits.GO == 1)       // Wait for the conversion to finish
           ;                            // ***  Loop till done
           LightOut = ADRESH;           //  move value to LightOut
           ADCON0 = 0x00;               // ADC turned off,
//           if(LightOut > LightTrip)   // is it dark out
//           {                          // Not yet, wait for switch to close
//              WaitForDoorOpening();
           if(LightOut <= LightTrip)    // is it dark?
           {                            // Yes it is dark, OK for PWM to run
               Cycle_The_Lights_Once(); //
            T2CON=0x07;                     // Timer2 setup configuration
            while(TMR2IF==0);               // test Timer interupt overflow bit, PWM timing
            TMR2IF=0;                       // Clear the Interupt flag
            PR2=0x7C;                       // Set the Period of the PWM output,
            PWM4CON=0xE0;                   // PWM control settings
            PWM4DCH = 0x00;                 // High Bits of the Duty cycle
            PWM4DCL = 0x00;                 // Low Bits of the Duty cycle. Not Needed. Register not being used.
                while(PWM4DCH < 0x7C)       // Max value is 0x7C ~100% Duty Cycle.
                                            // bring lights up in incriments
                     PWM4DCH = PWM4DCH++;   // Increase the duty cycle +1
                     UpDelay();             // Step interval to bring lights to turn up brightness
            PWM4DCH = 0x7C;                 // Increase the duty cycle +1
             for(Counter = 0;Counter < 90;Counter++)
             {                              // Duration of the Max PWM Duty Cycle next.
                 LongDelay();               // Time of 500 ms, to be 120 seconds in the end.
             while (PWM4DCH > 0x00)
                 PWM4DCH = PWM4DCH--;       // Decrease the duty cycle by 1
                 ShortDelay();              // Step interval to bring lights down in brightness
             T2CON = 0x00;                  // TMR2 Off till needed next time
    void UpDelay()
        __delay_ms(5);
        return;
    void ShortDelay()
        __delay_ms(40);
        return;
    void LongDelay()  // one second delay
        __delay_ms(1000);
        return;
ksmes
