scripting problrem ?
Discussion topics related to the 32-bit version of MPLAB IDE version 6.xx and later.
Postby alcofribas » Tue Jan 10, 2023 4:45 pm
Hi all
I'm using16F18855 because it has ADC and Timers...
My application :
Timer0 generates an IT every 100ms...
The ISR reads a potentiometer and stores the 10 bits value in a variable called A...( module Adcc.c)
So A is declared locally inside the ISR
in my main.c i declared A as extern to extend A's visibility...but, and that is my problem A is always zero, just as if A from the ISR is not A in main.c
Could someone point me to the right way to write such a small routine
thks in advance
A
alcofribas
Re: scripting problrem ?
Postby alcofribas » Tue Jan 10, 2023 6:24 pm
Found my bug...
Wrong place for global var...
alcofribas
Postby ric » Fri Jan 13, 2023 1:09 am
Indeed. The "declaration"(i.e. the line that ocntains the "extern" qualifier) belongs in a header file visible to both C files.
It must be a global variable (declared outside any function), not a local one.
Return to MPLAB 8 IDE
