my old Parallel EEproms programmer :)
It was based upon an ISA board (8bits) that I developed as a prototype back in 1991. It was used for some 5 years, maybe more, but I only created 2 of them. I should still have the schematics in Orcad 3 format
Am posting the code here, for some fun (MSDOS, C):
#include <stdio.h>
#include <ctype.h>
#include <stdlib.h>
#include <string.h>
#include <conio.h>
#include <io.h>
#include <dos.h>
#include <fcntl.h>
#include <time.h>
#define HIBYTE(x) ((x >> 8) & 0xff)
#define LOBYTE(x) (x & 0xff)
#define LOW_ADDRESS (Porta+0)
#define HIGH_ADDRESS (Porta+1)
#define DATA_PORT (Porta+2) // Autoincremento dopo inp
#define CONTROL_PORT1 (Porta+4)
#define CONTROL_PORT2 (Porta+3)
#pragma intrinsic( _enable, _disable )
void (_interrupt _far *oldtimer)( void );
void _interrupt _far newtimer( );
unsigned int Porta=0x300;
unsigned int BinaryFile=0;
unsigned int StartAddress=0;
unsigned int EndAddress;
long FileOffset=0l;
int DebugMode=0;
int TipoEprom=0;
int LongTime=0;
int Verify=0,PreTestBlank=0;
int Quiet=0;
int OptimizeFF=1;
unsigned int EraseTime=60; // 1 ora
void (_interrupt _far *OldCtrl_C)();
int RetVal=0;
int fExit;
unsigned int TickCheck;
unsigned long TickCount;
char *Eproms[]={
"2708",
"2716",
"2532",
"2732",
"2764",
"27128",
"27256",
"27512",
// bit 7 = program pulse
// bit 6 = Vpp ON
// bit 5 = pin 23
// bit 4 = pin 22
// bit 3 = pin 1
// bit 2 = pin 27
// bit 1 = +5 al pin 26
// bit 0 = lampada UV
// bit 15 = lampada UV
// bit 14 = Vpp 12/24
// bit 13 = +5 on/off
// bit 12 =
// bit 11 =
// bit 10 =
// bit 9 =
// bit 8 = Output Enable
// bit 7 = LED & program pulse
// bit 6 = pin 20
// bit 5 = pin 1
// bit 4 = pin 22
// bit 3 = pin 23
// bit 2 = pin 27 e 20
// bit 0 = pin 22
unsigned int ReadWord[]={
2+64+8192+256,
2+64+8192+256,
2+8192+256,
2+64+8192+256,
4+64+8192+256,
4+64+8192+256,
4+64+8192+256,
64+8192+256
unsigned int ProgramWord[]={
2+16+8+64+8192,
2+16+8+64+8192,
2+16+8+8192,
2+1+4+8192,
4+32+64+8192+16384,
4+32+64+8192/*+16384*/,
8192+16384
unsigned int ProgramPulseWord[]={
128+2+16+8+4+8192,
128+2+16+8+4+8192,
128+2+8+8192,
128+64+1+2+4+8192,
128+64+32+8192+16384,
128+64+32+8192/*+16384*/,
128+8192+16384
unsigned int StandByWord= 4+64+8192;
unsigned char KBytes[]={
1,
2,
4,
4,
8,
16,
32,
64
int check(unsigned int begin, unsigned int end) {
register int i; // long per le 27512
register int ch;
long t;
i=StartAddress;
outp(CONTROL_PORT1, HIBYTE(ReadWord[TipoEprom]));
outp(CONTROL_PORT2, LOBYTE(ReadWord[TipoEprom]));
outp(LOW_ADDRESS,i % 256);
outp(HIGH_ADDRESS,i / 256);
do {
if(LongTime) {
t=TickCount/100;
while(t--);
ch=inp(DATA_PORT);
if((!Quiet) || !(i & 0xff))
printf("Indirizzo: %04XH, byte: %02XH\r",i,(unsigned char)ch);
if(ch != 0xff) {
RetVal=3;
break;
i++;
} while(i<=EndAddress && !fExit && i);
outp(CONTROL_PORT1, HIBYTE(StandByWord));
outp(CONTROL_PORT2, LOBYTE(StandByWord));
return RetVal;
int dump(unsigned int begin, unsigned int end) {
register int i,ch;
char chcount[20];
unsigned int count;
long t;
begin-=begin & 16;
outp(LOW_ADDRESS,begin & 255);
outp(HIGH_ADDRESS,begin >> 8);
count=begin;
if(BinaryFile) {
setmode(fileno(stdout),O_BINARY);
do {
if(LongTime) {
t=TickCount/100;
while(t--);
ch=inp(DATA_PORT);
putc(ch, stdout);
count++;
} while((count <= end) && !fExit && count);
else do {
printf("\n%04X: ",count);
for(i=0; i<16; chcount[++i]=0) {
if(LongTime) {
t=TickCount/100;
while(t--);
ch=inp(DATA_PORT);
count++;
printf("%02X%c",ch,i==7 ? '-' : ' ');
chcount[i]=isprint(ch) ? ch : '.';
printf(" %s",chcount);
return 0;
int program(unsigned int begin, unsigned int end, FILE *f, long offset, int mode) {
register int i,j;
int ch,ch1,bVuota=1;
// int RetVal=0;
long t;
if(BinaryFile) {
setmode(fileno(stdin),O_BINARY);
if(offset) {
fseek(f,offset,SEEK_SET);
fprintf(stderr, "Offset dall'inizio del file: %lXH\n", offset);
if(!mode) {
outp(CONTROL_PORT1, HIBYTE(ProgramWord[TipoEprom]));
outp(CONTROL_PORT2, LOBYTE(ProgramWord[TipoEprom]));
t=clock()+1000l;
while(clock() <= t); // importante affinchŠ +25VPP carichi il condensatore
else {
t=TickCount/10;
while(t--);
for(i=begin; i<=end; i++) {
if(!mode) {
outp(LOW_ADDRESS,LOBYTE(i));
outp(HIGH_ADDRESS,HIBYTE(i));
if(BinaryFile) {
j=ch=getc(f);
else {
j=fscanf(f,"%x",&ch);
if(j == EOF) {
puts("Attenzione: sono stati forniti meno dati della lunghezza della Eprom");
break;
if(fExit) {
break;
if(!mode) {
printf("Indirizzo: %04XH, byte: %02XH%c",i,(unsigned char)ch,
1 ? '\r' : '\n');
if((!OptimizeFF) || (ch != 0xff)) {
outp(DATA_PORT,ch);
// t=clock();
// while(clock() == t);
outp(CONTROL_PORT1, HIBYTE(ProgramPulseWord[TipoEprom]));
outp(CONTROL_PORT2, LOBYTE(ProgramPulseWord[TipoEprom]));
t=TickCount;
while(t--);
t=TickCount/2;
while(t--);
else {
if(LongTime) {
t=TickCount/20;
while(t--);
ch1=inp(DATA_PORT);
if((!Quiet) || (ch != ch1))
printf("Indirizzo: %04XH, byte letto: %02XH, byte da confrontare %02XH%c",
i,ch1,(unsigned char)ch, (ch==ch1) ? '\r' : '\n');
if(ch != ch1) {
RetVal=3;
if(ch1 != 0xff) {
bVuota=0;
if(mode && bVuota)
puts("Attenzione: la EPROM non contiene dati.");
putchar('\n');
return RetVal;
int ErrorExit(int modo) {
char buffer[64];
switch(modo) {
case 1:
strcpy(buffer,"funzione inesistente");
break;
case 2:
strcpy(buffer,"switch sconosciuto");
break;
case 3:
strcpy(buffer,"");
break;
case 4:
strcpy(buffer,"interruzione dell'utente");
break;
if(modo && (modo != 3))
fprintf(stderr,"\nErrore: %s\n\n",buffer);
_dos_setvect(0x23,OldCtrl_C);
exit(modo);
#pragma check_stack(off)
void _interrupt _far Ctrl_C() {
_asm {
mov word ptr RetVal,4
mov word ptr fExit,1
// pop bp
// iret
#pragma check_stack(on)
int main(int argc, char *argv[]) {
char Args[20][40];
register i,j;
char opts[40];
char *t;
int k;
long l;
long m;
fprintf(stderr,"\nProgrammatore di Eprom v1.60 - (C) G.Dar 1991-2000\n");
fprintf(stderr," (C) ADPM Synthesis 1992-2000\n");
if((argc<2) || (*argv[1]=='?')) {
puts("\nSintassi: EPROM <funzione> [/switch]");
puts("Funzione: 1 ... controlla contenuto Eprom cancellata");
puts(" 2 ... dump della Eprom");
puts(" 3 ... programma la Eprom");
puts(" 4 ... verifica la Eprom");
puts(" 5 ... cancella la Eprom");
puts("Switch: /p<numero hex> ... indirizzo base I/O");
puts(" /t<sigla Eprom> ... imposta tipo Eprom");
puts(" /s<offset hex> ... indirizzo iniziale");
puts(" /e<offset hex> ... indirizzo finale");
puts(" /o<offset hex> ... offset nel file");
puts(" /b ... specifica dati binari durante programmazione");
puts(" /q ... sopprime contatore indirizzi");
puts(" /a ... controlla canc. prima della programmazione");
puts(" /v ... verifica dopo la programmazione");
puts(" /f ... disabilita ottimizzazione FF");
puts(" /l ... allunga impulsi PRG, per memorie lente");
puts(" /c ... specifica tempo di cancellazione in minuti");
puts("Errorlevel: 0=OK, 1=Errore esecuzione, 2=Errore comandi,");
puts(" 3=Errore svolgimento, 4=Interruzione.");
exit(99);
OldCtrl_C=_dos_getvect(0x23);
_dos_setvect(0x23,Ctrl_C);
fExit=0;
// Estrae opzioni della command line: /s o -s
for(i=1; i<argc; i++)
strcpy(Args[i],argv[i]);
*opts=0;
for(i=1; i<argc; i++) {
if(*Args[i]=='/' || *Args[i]=='-') {
strcat(opts,((char *)(Args[i]))+1);
strcat(opts,"~");
for(j=i; j<argc; j++)
strcpy(Args[j],Args[j+1]);
*Args[j-1]=0;
i--;
argc--;
strupr(opts);
if(t=strchr(opts,'C')) {
sscanf(t+1,"%u",&EraseTime);
if(t=strchr(opts,'D')) {
DebugMode=1;
if(t=strchr(opts,'P')) {
sscanf(t+1,"%x",&Porta);
if(t=strchr(opts,'Q')) {
Quiet=1;
if(t=strchr(opts,'F')) {
OptimizeFF=0;
if(t=strchr(opts,'B')) {
BinaryFile=1;
if(t=strchr(opts,'V')) {
Verify=1;
if(t=strchr(opts,'A')) {
PreTestBlank=1;
if(t=strchr(opts,'L')) {
sscanf(t+1,"%d",&LongTime);
if(LongTime>10)
LongTime=10;
if(t=strchr(opts,'T')) {
TipoEprom=-1;
for(i=0; *Eproms[i]; i++) {
if(*(t+1) == '?') {
puts(Eproms[i]);
else {
if(!strncmp(t+1,Eproms[i],strlen(Eproms[i]))) {
TipoEprom=i;
break;
if(TipoEprom < 0)
ErrorExit(2);
if(t=strchr(opts,'O')) {
sscanf(t+1,"%lx",&FileOffset);
if(t=strchr(opts,'S')) {
sscanf(t+1,"%x",&StartAddress);
if(t=strchr(opts,'E')) {
sscanf(t+1,"%x",&EndAddress);
if(!EndAddress) {
EndAddress=KBytes[TipoEprom] * 1024-1;
fprintf(stderr,"\nEprom scelta: %s\n",Eproms[TipoEprom]);
fprintf(stderr,"Range di indirizzi di lavoro %04XH - %04XH\n",
StartAddress,EndAddress);
fprintf(stderr,"Base I/O: %X (hex)\n\n",Porta);
RetVal=0;
// Misura clock di sistema
oldtimer = _dos_getvect( 8);
_dos_setvect( 8, newtimer );
_asm {
push si
push di
mov word ptr TickCheck,0
xor di,di
xor si,si
aspetta:
cmp TickCheck,1
jne aspetta
aspetta_:
cmp TickCheck,2
je fine
inc di
jne aspetta_
inc si
jne aspetta_
fine:
mov word ptr m,di
mov word ptr m+2,si
pop di
pop si
_dos_setvect( 8, oldtimer );
if(LongTime) {
m/=4;
TickCount=m*LongTime;
else
TickCount=m/10; // era /8, 19-11-93
if(DebugMode) {
fprintf(stderr,"Conteggi in un tick (%u millisecondi): %lu\n",10000/182,m);
fprintf(stderr,"Program pulse=%3.1f mSec\n",((double)TickCount)*10000.0/182.0/((double)m));
switch(*Args[1]) {
case '1':
check(StartAddress,EndAddress);
if(!RetVal || (RetVal==3))
printf("\nLa Eprom %s correttamente cancellata.\n", RetVal ? "non Š\a" : "Š");
break;
case '2':
dump(StartAddress,EndAddress);
break;
case '3':
if(PreTestBlank)
if(check(StartAddress,EndAddress)) {
printf("\nLa Eprom non Š correttamente cancellata.\n");
goto no_program;
program(StartAddress, EndAddress, stdin, FileOffset, 0);
printf("\nProgrammazione %s.\n", RetVal ? "fallita\a" : "OK");
if(Verify) {
RetVal=0;
fseek(stdin,0,SEEK_SET);
t=clock()+500l;
goto verify;
no_program:
break;
case '4':
verify:
program(StartAddress, EndAddress, stdin, FileOffset, 1);
printf("\nLa verifica %s OK.\n", RetVal ? "non Š\a" : "Š");
break;
case '5':
outp(CONTROL_PORT1, 128);
outp(CONTROL_PORT2, 0);
l=clock()+EraseTime*60000l;
while((clock() <= l) && !fExit) {
if(!Quiet)
printf("Cancellazione Eprom, ancora %u minuti...\r",
((unsigned int)((l-clock())/60000L)));
break;
default:
RetVal=1;
break;
ErrorExit(RetVal);
void _interrupt _far newtimer() {
TickCheck++;
_chain_intr( oldtimer );
