can I make the MPLab X IDE display all variables as decimal
Postby roujesky » Sat Jun 14, 2014 12:42 am
The IDE wants to display all variables in HEX by default. IS there a way to make the IDE display variables in decimal by default? I know i can click on a variable row in the window and "display variable as...", but I have to do this for every new variable I add.
Thanks!
roujesky
Re: can I make the MPLab X IDE display all variables as deci
Postby jtemples » Sat Jun 14, 2014 8:00 am
Right click on the watch window's header, then select decimal.
Postby Ian.M » Sat Jun 14, 2014 9:54 am
.... err, I think he may asking about the 'Variables' window! The watch window's easy because you can add columns for other formats.
Postby jtemples » Sat Jun 14, 2014 10:50 am
"Variables" works exactly the same way.
Postby dbhughe » Fri Jun 27, 2014 6:27 am
How about when you hover over the variable in the source code. Sometimes it would be convenient to see the value in something other than hexadecimal.
dbhughe
Return to MPLAB X IDE
