XPlorer 16/32 Dev Board - SPI for TFT Color Display
Discussion on Microchip's wide line of Evaluation and Demonstration Boards.
Postby GGRUK » Mon Sep 12, 2022 10:03 am
Hi
I found this old thread about XPlorer16 Dev Board and an issue with SPI. Although, this thread is about the conflict between USB & SPI, I think this is the only thread I found to post my difficulties with XPlorer16/32 Board with SPI.
I am using PIC24FJ256GB410 PIM and trying to communicate with a TFT color display 80x160 using SPI. I have the code provided by the manufacturer of the display EA Germany. I am using the MIKR BUS A to connect SPI pins to the display. It did work for some hours. But when I disconnected the 9V dc Power supply and connected it again, it stopped working. Since then it does not work.
I am able to see all the signals on the pins of Mikro Bus A (SCK, MOSI, CS and other pins like VCC, GND, RS(D/C selection for the display), Display RESET pin and also the SDA pin on the display. I see these on Logic Pro. All values seem to be correct. When I wrote a simple loop to send repeated commands to the display, Logic Pro shows them correctly as sent. But nothing happens on the display.
Is there an issue of conflict or 'cross-over' of RX & DX pins, as stated on SPI1?
Could this be the reason why nothing is actually sent to the display?
I am using the following pins on Mikro BUS A for SPI connection to the display.
I have configured SPI as spi3 on the PIC PIM
Pin 1 of J20: ANP25: RS(D/C choice on display in a 4 wire interface)
Pin 2 of J20: P95: RESET for display
Pin 3 of J20: P14: CSA
Pin 4 of J20: P10: SCKA
Pin 5 of J20: P11: MISO this is connected directly to SDA of display (although I don't read the display)
Pin 6 of J20: P12: MOSI connected to SDA through 100R
Pin 7 of J20: 3.3V connected to VCC of display
Pin 8 of J20: GND connected to GND of display.
The LED backlight A & K are connected between 3.3V & GND through a potentiometer where I can vary the current.
Currently backlight is ON and I can vary the brightness with LED current from 5mA to 20mA - currently set at 10mA
The 4W pin on the display is connected to 3.3V to put SPI into 4 wire mode.
I have tried first with Winstar 0.96" display (80x16) where the code ran and I could see the colour display in demo mode for several hours. Since it has stopped working after OFF-ON of the 9V power supply, I have tries two other makes of the displays of similar types. But nothing is seen.
I am going to try to use the pins on Mikro Bus B if this can solve the problem.
Or is it better that I don't use the pins meant for USB and connect to tother pins if available for SPI on the main ?
Thanks in advance. Please ask if you need any more details.
GGRUK
GGRUK
Re: XPlorer 16/32 Dev Board - SPI for TFT Color Display
Postby GGRUK » Mon Sep 12, 2022 10:04 am
Hi ric
Follwoing your suggestion, I have posted my issue here.
Please help and also guide how to ensure that the XPlorer board is working.
GGRUK
GGRUK
Return to Evaluation and Demonstration Boards
Users browsing this forum: No registered users and 12 guests
