Sleep mode with PIC16F18345
The PIC I'm using has three power off modes: DOZE mode, IDLE mode, and standby mode (P113). I would like using the button to vary these three modes by an interruption.
On my test plate, I put a push button connected to RC5 (at rest 5V on RC5 and if a press on the BP, 0V on RC5), I thus wish to use the interrupts and the different mode of consumption of the mode sleep of my PIC16F18345
1 / BP at rest-> no interruption on RC5-> PIC in SLEEP mode
2 / Press BP-> interrupt on RC5-> PIC in DOZE mode -> Program in operation
3 / RE Press BP-> interrupt on RC5-> stop program-> PIC in IDLE Mode
My current code does the following thing: power on -> sleep mode, press the button -> normal mode
I can not vary the different modes. Thank you in advance !
// CONFIG1
#pragma config FEXTOSC = OFF // FEXTOSC External Oscillator mode Selection bits (Oscillator not enabled)
#pragma config RSTOSC = HFINT1 // Power-up default value for COSC bits (HFINTOSC (1MHz))
#pragma config CLKOUTEN = OFF // Clock Out Enable bit (CLKOUT function is disabled; I/O or oscillator function on OSC2)
#pragma config CSWEN = ON // Clock Switch Enable bit (Writing to NOSC and NDIV is allowed)
#pragma config FCMEN = ON // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
// CONFIG2
#pragma config MCLRE = ON // Master Clear Enable bit (MCLR/VPP pin function is MCLR; Weak pull-up enabled)
#pragma config WDTE = OFF // Watchdog Timer Enable bits (WDT disabled; SWDTEN is ignored)
#pragma config LPBOREN = OFF // Low-power BOR enable bit (ULPBOR disabled)
#pragma config BOREN = OFF // Brown-out Reset Enable bits (Brown-out Reset disabled)
#pragma config BORV = LOW // Brown-out Reset Voltage selection bit (Brown-out voltage (Vbor) set to 2.45V)
#pragma config PPS1WAY = ON // PPSLOCK bit One-Way Set Enable bit (The PPSLOCK bit can be cleared and set only once; PPS registers remain locked after one clear/set cycle)
#pragma config STVREN = ON // Stack Overflow/Underflow Reset Enable bit (Stack Overflow or Underflow will cause a Reset)
#pragma config DEBUG = OFF // Debugger enable bit (Background debugger disabled)
// CONFIG3
#pragma config WRT = OFF // User NVM self-write protection bits (Write protection off)
#pragma config LVP = ON // Low Voltage Programming Enable bit (Low Voltage programming enabled. MCLR/VPP pin function is MCLR. MCLRE configuration bit is ignored.)
// CONFIG4
#pragma config CP = OFF // User NVM Program Memory Code Protection bit (User NVM code protection disabled)
#pragma config CPD = OFF // Data NVM Memory Code Protection bit (Data NVM code protection disabled)
// PORT A
#define ICSPDAT RA0 // Port de programmation
#define POWER RA1 // Retour d etat charge batterie
#define MCLR RA3 // Port de programmation
// PORT B
#define ledR RB7 // +LED rouge
// PORT C
#define BP RC5 // Bouton poussoir
#define ON 0 // Led tirée au +VCC
#define OFF 1 // Led tiréé au gnd
//#define _XTAL_FREQ 1000000 // Oscillateur réglé à 1MHz
//int etat_Bp; // Variable bouton
#include <pic16f18345.h>
void interrupt ISR ()
if(PIE0bits.IOCIE) // IT changement d'etat bouton
CPUDOZEbits.IDLEN = 1;
IOCCFbits.IOCCF5 = 0; // RAZ flag IT
else if (PIE0bits.IOCIE){
CPUDOZEbits.DOZEN = 1;
void main(void) {
OSCCON1 = 0x37; // Oscillateur interne
OSCFRQ = 0x06; // Frequence oscillateur a 16MHz
CPUDOZE = 0x00; // Choix DOZE/IDLE mode pour economie d energie en veille
VREGCON = 0x03; // Choix DOZE/IDLE mode pour economie d energie en veille
// Reglages des entrees/sorties
TRISA = 0x37; // Choix entrees/sorties
LATA = 0x00; // RAZ des ports
ANSELA = 0x37; // Choix mode analogique/numerique
WPUA = 0x20; // Resistances de pull-up interne
TRISB = 0xFF; // Choix entrees/sorties
LATB = 0x00; // RAZ des ports
ANSELB = 0x70; // Choix mode analogique/numerique
WPUB = 0x00; // Resistances de pull-up interne
TRISC = 0xFF; // Choix entrees/sorties
LATC = 0x00; // RAZ des ports
ANSELC = 0xDF; // Choix mode analogique/numerique
WPUC = 0x20; // Resistances de pull-up interne
//WDTCON = 0x3C;
//Reglage des interuptions
INTCON = 0b11000000; // Autorisation des interruptions : GIE=1, PEIE=1 , INTED=0 donc sur front descendant
IOCCNbits.IOCCN5 = 1; // Interruption sur la pin RC5 negative activee
PIE0bits.IOCIE = 1; // Valide le changement d'etat
SLEEP();
while(1){
