struct T_XPOMObject {
unsigned char XPOMInstruction[XPOM_MaxLength];
unsigned char XPOMValue[XPOM_DataLength];
int XPOMEEAddr[XPOM_DataLength];
unsigned char XPOMLength;
unsigned char XPOMCounter;
struct T_XPOMObject XPOMBuffer[XPOMBufferLength];
unsigned char sequenceNumber_SS;
and used them in this function:
void putXPOMToBuffer(unsigned char packet_idx){
unsigned char x;
ix=0;
while (packet_idx<packetLength) {
//(when following was written as one command, XC8 issued a warning that this command is candidate for compiler verify
x=packet[packet_idx++];
XPOMBuffer[sequenceNumber_SS].XPOMInstruction[ix]=x;
ix++;
and tryied to debug my code using simulator in MPLAB X-IDE as usual.
But XPOMBuffer[sequenceNumber_SS].XPOMInstruction[0] get corrupted always when ix=2. But this was also always the moment, when Simulator issued an TMR0 IRQ during the _WMUL function. Because the code was OK for other ix, the ISR code was clear suspect. Finally I went to assembler and quickly realized that XC8 2.30 doesn't properly recover context when returning from ISR!
As you can see in the following XC8 generated asm code, although the ISR routine saves and restores all registers used as stated in manual, it's buggy.
When you check the asm code thoroughly, you'll see, that it saves 126 to ??isr+8, but restores it back from ??_isr+9 , and when you check all the saved registers, it's even worser - ALL are "recovered" same way
20332 ;; *************** function _isr *****************
20369 ; Regs used in _isr: [wreg-fsr0h+fsr1l+fsr1h+status,2-btemp+1+btemp+4-btemp+11+pclath+cstack]
20370 0004 3180 pagesel $
20371 0005 0874 movf 116,w
20372 0006 0020 movlb 0 ; select bank0
20373 0007 00A0 movwf ??_isr
20374 0008 0875 movf 117,w
20375 0009 00A1 movwf ??_isr+1
20376 000A 0878 movf 120,w
20377 000B 00A2 movwf ??_isr+2
20378 000C 0879 movf 121,w
20379 000D 00A3 movwf ??_isr+3
20380 000E 087A movf 122,w
20381 000F 00A4 movwf ??_isr+4
20382 0010 087B movf 123,w
20383 0011 00A5 movwf ??_isr+5
20384 0012 087C movf 124,w
20385 0013 00A6 movwf ??_isr+6
20386 0014 087D movf 125,w
20387 0015 00A7 movwf ??_isr+7
20388 0016 087E movf 126,w
20389 0017 00A8 movwf ??_isr+8
20390 0018 087F movf 127,w
20391 0019 00A9 movwf ??_isr+9
20392 001A 3011 movlw low ___int_sp
20393 001B 0086 movwf 6
20394 001C 3024 movlw high ___int_sp
20395 001D 0087 movwf 7
20396 001E 0875 movf 117,w ;;unnecessary 2nd save of 117
20397 001F 00AA movwf ??_isr+10
20398
20399 ;interrupts.c: 39: if ((INTCONbits.TMR0IE) && (INTCONbits.TMR0IF)){
--- here was the ISR code ---
20493 0059 0020 movlb 0 ; select bank0
20494 005A 082A movf ??_isr+10,w ;;wrong offset 10 instead of 9
20495 005B 00FF movwf 127
20496 005C 0829 movf ??_isr+9,w
20497 005D 00FE movwf 126
20498 005E 0828 movf ??_isr+8,w
20499 005F 00FD movwf 125
20500 0060 0827 movf ??_isr+7,w
20501 0061 00FC movwf 124
20502 0062 0826 movf ??_isr+6,w
20503 0063 00FB movwf 123
20504 0064 0825 movf ??_isr+5,w
20505 0065 00FA movwf 122
20506 0066 0824 movf ??_isr+4,w
20507 0067 00F9 movwf 121
20508 0068 0823 movf ??_isr+3,w
20509 0069 00F8 movwf 120
20510 006A 0822 movf ??_isr+2,w
20511 006B 00F5 movwf 117
20512 006C 0821 movf ??_isr+1,w
20513 006D 00F4 movwf 116
20514 006E 0009 retfie
20515 006F __end_of_isr:
And this is the piece of code with field index computation which gets corrupted:
11755 ;instructions.c: 123: XPOMBuffer[sequenceNumber_SS].XPOMInstruction[ix]=x;
11756 1A76 0021 movlb 1 ; select bank1
11757 1A77 084C movf _ix^(0+128),w ;volatile
11758 1A78 00FE movwf 126 ;;save index to field to 126&127
;;IRQ after this point corrupts the computed address
11759 1A79 01FF clrf 127
11760 1A7A 3016 movlw 22 ;;size of struct XPOM_Object
11761 1A7B 001E movwi fsr1++
11762 1A7C 3000 movlw 0
11763 1A7D 001E movwi fsr1++
11764 1A7E 0020 movlb 0 ; select bank0
11765 1A7F 085F movf _sequenceNumber_SS,w
11766 1A80 001E movwi fsr1++
11767 1A81 3000 movlw 0
11768 1A82 001E movwi fsr1++
11769 1A83 31A0 200F 319A fcall ___wmul ; compute offset to XPOMBuffer[Sequence#SS] for XPOM_OBject
11770 1A86 3098 movlw 152 ;base address of XPOMInstruction[] in XPOMBUffer[0] LSB
11771 1A87 00FC movwf 124
11772 1A88 3027 movlw 39 ;base address of XPOMInstruction[] in XPOMBUffer[0] MSB
11773 1A89 00FD movwf 125
11774 1A8A 0874 movf 116,w ;offset returned from WMUL to XPOMBuffer[sequenceNumber_SS].XPOMInstruction[0] LSB
11775 1A8B 077C addwf 124,w
11776 1A8C 00FA movwf 122
11777 1A8D 0875 movf 117,w ;;offset returned from WMUL to XPOMBuffer[sequenceNumber_SS].XPOMInstruction[0] MSB
11778 1A8E 3D7D addwfc 125,w ;
11779 1A8F 00FB movwf 123 ;computed base address of XPOMBuffer[sequenceNumber_SS].XPOMInstruction[0]
11780 1A90 087E movf 126,w ;and now add the ix offset LSB XPOMBuffer[sequenceNumber_SS].XPOMInstruction[ix]
11781 1A91 077A addwf 122,w
11782 1A92 00FC movwf 124
11783 1A93 087F movf 127,w ;;and now add the ix offset MSB
11784 1A94 3D7B addwfc 123,w
11785 1A95 00FD movwf 125
11786 1A96 087C movf 124,w
11787 1A97 0084 movwf 4 ;;copy the computed address to FSR0L+FSR0H
11788 1A98 087D movf 125,w
;till this point can the faulty ISR corrupt the computed address
11789 1A99 0085 movwf 5
11790 1A9A 0020 movlb 0 ; select bank0
11791 1A9B 082B movf putXPOMToBuffer@x,w
11792 1A9C 0080 movwf 0 ;;and finally save the value X using FSR0 and IND0
11793
11794 ;instructions.c: 124: ix++;
When the IRQ appears in the middle of computing complex address this will lead to computing wrong index. If this is part of a write to a variable, you end with mysteriosly corrupted data.
Computing the address starts with saving the offset to fixed adress 126 and eventually 127. After that the base address is computed by _WMUL and finally added the offset from 126+127.
When an IRQ appears between saving the offset to 126/127 and reading it back, the adress gets corrupted. In my case the IRQ occurs during _WMUL which is a reentrant 16 bit unsigned multiply routine from library.
Because 126 get the value from 127 (which in this case is 0), the value was writen to first variable of the array [0] where it could be easilly observed.
When the IRQ should appeared later, it could more significantly change the address and the value could be written somewhere in the memory casuing really mysterious errors.
I'm really surprised, that rest of my code worked some way. May be it's so because most of the code is someway "synchronized" by TMR0 and IRQ appears almost at same places of code.
But during debugging other parts of code I realized that some code using arrays sometimes doesn't run OK, but when I added some code, the problem mysteriously disappeared.
Because this part dealed with flash memory driven by ISR, which is not in sync with rest of code, I simply couldn't found the reason.
I don't know if this is only special case, but such ISR restore makes any afflicted code unstable and useless.
My project used PIC16F1789, PIC12-16Fxxx.DFP 1.2.63, Hybrid stack, C90, XC8 2.30 with free license and optimization level S2. Tryied to use XC8 2.32 with same result
BTW, during debugging I changed all local variables from ISR called functions to global and set as volatile as recommended, but without any change of behaviour.
So, how to deal with this bug?
Because my code should run in a real time, I found using _WMUL to slow. So without worrying about the ISR problem, I tried to rewrite the code to avoid using _WMUL.
The declaratinon was almost same, but instead of using indexes to array of structures as above, I used a pointer to every single structure. It seems weird, but XC8 used
the pointer as base and when addressing a variable in the structure adds a constant. This is much quicker then _WMUL and also has the effect that the XC8 doesn't
save in ISR so many registers and restores them in a proper way
struct T_XPOMObject XPOMBuffer[XPOMBufferLength]; //Buffer for XPOM instructions
struct T_XPOMObject *XPOMPtr[XPOMBufferLength], *XP_Ptr; //Pointers to XPOM instructions
void putXPOMToBuffer(unsigned char sequenceNumber, unsigned char packet_idx){
struct T_XPOMObject *XP;
unsigned char i=0;
XP=XPOMPtr[sequenceNumber];
XP->XPOMInstruction[i++]=packet[packet_idx++]; //ISR doesn't corrupt this and also candidate for compiler verify warning isn't issued anymore
and right ISR routine:
20579 0004 _isr:
20580
20581 ;incstack = 0
20582 ; Regs used in _isr: [wreg-fsr0h+fsr1l+fsr1h+status,2-btemp+0+btemp+6-btemp+11+pclath+cstack]
20583 0004 3180 pagesel $
20584 0005 0874 movf 116,w
20585 0006 0020 movlb 0 ; select bank0
20586 0007 00A0 movwf ??_isr
20587 0008 087A movf 122,w
20588 0009 00A1 movwf ??_isr+1
20589 000A 087B movf 123,w
20590 000B 00A2 movwf ??_isr+2
20591 000C 087C movf 124,w
20592 000D 00A3 movwf ??_isr+3
20593 000E 087D movf 125,w
20594 000F 00A4 movwf ??_isr+4
20595 0010 087E movf 126,w
20596 0011 00A5 movwf ??_isr+5
20597 0012 087F movf 127,w
20598 0013 00A6 movwf ??_isr+6
20599 0014 3011 movlw low ___int_sp
20600 0015 0086 movwf 6
20601 0016 3024 movlw high ___int_sp
20602 0017 0087 movwf 7
20603
20604 ;interrupts.c: 39: if ((INTCONbits.TMR0IE) && (INTCONbits.TMR0IF)){
----------- here was the ISR code ------------
20698 0051 0020 movlb 0 ; select bank0
20699 0052 0826 movf ??_isr+6,w
20700 0053 00FF movwf 127
20701 0054 0825 movf ??_isr+5,w
20702 0055 00FE movwf 126
20703 0056 0824 movf ??_isr+4,w
20704 0057 00FD movwf 125
20705 0058 0823 movf ??_isr+3,w
20706 0059 00FC movwf 124
20707 005A 0822 movf ??_isr+2,w
20708 005B 00FB movwf 123
20709 005C 0821 movf ??_isr+1,w
20710 005D 00FA movwf 122
20711 005E 0820 movf ??_isr,w
20712 005F 00F4 movwf 116
20713 0060 0009 retfie
20714 0061 __end_of_isr:
I don't know the real reason why the XC8 changed the behaviour. But the mix of 'an array in a structure in an array' was for XC8 probably some way "toxic".
What is wrong with XC8? In my opinion it's the second unnecessary save of register 117. This increases the index to 10. And this index is then used for restore code and all goes wrong
